Old 27-03-2011, 12:19 PM   #1
gilbertthegreat
gilbertthegreat's Avatar
Default Propylene glycol antifreeze/coolant
Gudday
Does anyone know of a brand of coolant/antifreeze that uses propylene glycol instead of ethylene glycol, and is available in Australia?
Shaun
http://www.pa-hire.net.au South Coast PA Hire
gilbertthegreat is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2011, 09:13 PM   #2
Dr Smith
Default Re: Propylene glycol antifreeze/coolant
Originally Posted by gilbertthegreat
Gudday
Shaun
Any reason you want PG based over EG?
Found these but can't say good or bad:
http://zbikesunlimited.com.au/AMSOIL2.html
http://www.shopping.com/Antifreeze-C...stone/products
http://www.mavlon.com.au/coolant-products
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2011, 11:50 PM   #3
ohzone
Dent Removal
ohzone's Avatar
Don't know which brands, but a little bit of general info on the two
Propylene glycol and ethylene glycol are both used as antifreeze for cars and trucks They are chemically similar in many respects, with propylene glycol considered to be a safer alternative than its ethylene cousin; however, ethylene glycol has better heat transfer properties. Although propylene glycol antifreeze has less coolant ability and is less toxic than ethylene glycol, mixing them won't lessen toxicity or have a major effect on cooling ability.
Read more: How to Mix Propylene Glycol & Ethylene Glycol | eHow.com http://www.ehow.com/how_6385941_mix-...#ixzz1Hnst3NwG
ohzone is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2011, 12:44 AM   #4
XR Martin
XR Martin's Avatar
Go to a Toyota dealer and get their genuine stuff, it'll be as good as any.
2004 BA wagon RTV project.
Old 01-04-2011, 09:39 AM   #5
gilbertthegreat
Thanks guys
I ended up getting some from www.enginecare.com.au
Much appreciated info.
Thread Tools
Display Modes
