Old 01-09-2015, 06:37 PM   #1
AaronDugs
AaronDugs's Avatar
Default weep from intake manifold?
Hey guys ive noticed this weep for a while, i dont think its gotten any worse but im just curious if anyones came across the same thing? Its deffinatly from the intake manifold and not oil from the rocker cover.
99 AU Futura Granpa Spec
AaronDugs is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2015, 06:49 PM   #2
Default Re: weep from intake manifold?
If the gasket has failed there the blowby gases will produce that colour leakage. Get a length of windscreen washer sized hose and stick one end in your ear while listening for a air leak there at idle with engine both hot and cold. If it is leaking you should also see uneven idle or a delayed reduction in revs when you stop.
Old 01-09-2015, 07:22 PM   #3
AaronDugs
AaronDugs's Avatar
Oh sweet i was planning on changing the gasket this weekend due to slight rough idle, now i know for sure cheers mate!
Old 01-09-2015, 10:33 PM   #4
Remember to torque the nuts on the manifold up in a circular pattern like a head gasket and don't put the gasket on upside down and back to front (it will fit that way but will block of the injectors spray).
Old 03-09-2015, 08:31 PM   #5
AaronDugs
AaronDugs's Avatar
Ohk cheers heaps ill keep that in mind, bottom bolts look like quite a pain but i should be right
Thread Tools
Display Modes
