#61 | ||
![]() Join Date: Jan 2005
Not much difference in any of the stock brakes - they are all pretty much the same from AU2 through to BF (287 or 298 fronts, etc). The only real upgrade would be the PBR kit available for BA/BF (and therefore I assume AU2/3 as well), or the premium setup from AU2 through to BF.
Here's the fitment guide from dba: AU II, AU III - all models 2000 - on F 502 Vented 287 65 28 25.6 71.8 5 R 503Solid 287 51 16 14.5 70.5 5 BA 4.0L DOHC 2002 - on F 504 Vented 298 65 28 26 70.5 5 4.0L Turbo 5.4L V8 4V R 505 Solid 303 51 16 14.5 70.5 5
#62 | ||
Irregular Member
Thanks for shedding some light on it.Atleast i now know not to hunt around for a different model.
#63 | |||
http://www.fordforums.com.au/showthread.php?t=41093 Cheers |
#64 | ||
Here it is again, for those who can't search:
Standard AUI: - Front: Single Piston Caliper to hold a 287mm Disc - Rear: Single Piston Caliper to hold a 287mm Disc Standard AUII/III: - Front: Twin Piston Caliper to hold a 287mm Disc - Rear: Single Piston Caliper to hold a 287mm Disc Tickford/Premium AU Setup: - Front: Twin Piston Caliper to hold a 330mm Disc - Rear: Single Piston Caliper to hold a 287mm Disc BA (incl XR): - Front: Twin Piston Caliper to hold a 298mm Disc - Rear: Single Piston Caliper to hold a 303mm Disc BA Premium Brakes: - Front: Twin Piston Caliper to hold a 325mm Disc - Rear: Single Piston Caliper to hold a 303mm Disc FPV: - Front: Twin Piston Caliper to hold a 330mm Disc - Rear: Single Piston Caliper to hold a 303mm Disc I think thats mostly correct. As you can see on the BA's they got a larger rear disc, but slightly smaller front disc (than the Tickford setup), unless you get a FPV setup as fitted to the FPVs.
#65 | |||
Irregular Member
#66 | ||
Ripping it up
does the fpv rotor/caliper setup (ba on) just bolt straight up to the au2/3???
#67 | ||
Mr Cube has bolted BA brakes to his AU1 (had to replace spindles etc to AU2 spec), which suggests that any of the BA brakes would bolt up as well, as long as you got the right calipers for the larger discs, etc.
#68 | |||
#69 | ||
For the Tickford/FPV Setup anyway, for the caliper to hold the larger disc, you need the braket, which helps it stick out and up. Not sure about the BA/BF Brakes. But will be much less costly than the Tickford setup. And i see no reason why it shouldnt just be a bolt on job. And having 303mm discs in the rear, will look alright.
#70 | ||
XB in parts...
Any chance we could have the AU1 > AU2 brake conversion put up as an article on the aufalcon.com site ?
Its a commonly asked question....
Daily Driver 2019 Ford Escape...looking for XR6T's. |
#71 | |||
GT-P #0336
![]() ![]() ![]() ![]() ~Tuned By Bluepower Racing~ |
#72 | ||
GT-P #0336
After just buying the CT's, I've now been told they don't pull up (so many different opinions) so can someone tell me which is the better choice so that I can decide whether to swap them. Should I stay with the CT's or go with Advance?
I'm pretty hard on my brakes, that's my driving style, so which will suit better? And especially after all the go fast mods and more to come shortly, I need something that will be up for the task until I can afford the conversion.
#73 | ||
GT-P #0336
Oh and I forgot to ask about this - are PBR calipers good?
#74 | ||
Not sure about the CTs as I 've never used them.
PBR make the standard Ford calipers, as well as the upgraded sports brakes for AU2 - BF..
#75 | ||
Irregular Member
Id like to know what improvement the PBR brake package(with the colored calipers) is over running the ford callipers with slotted DBA rotors and decent pads?
#76 | |||
beep beep
Noticable difference of multiple high speed stops at high aggression levels. You might want to read this: http://www.fordforums.com.au/vbporta...article&id=220
Nothing to see here, move along, move along... |
#77 | ||
Just a question... To change front pads on an AU 1....do I need any special tools, and how long to do the job???
Thanks, Mark |
#78 | ||
Use a G clamp to push the piston back in.. the rest comes off with a couple of sockets.
and generally if you have the right tools and know how to do the job I give it 20-30mins to do both fronts.. |
#79 | |||
Walking with God
For the front we used, 13mm ring spanner, elbow grease, piston depression tool to get the piston all the way back in, 10mm spanner for the brake bleeding nipple, one way valved brake bleeding tool, brake fluid. Instead of the piston depression tool, a g clamp would work ok too I reckon! Oh and I needed to give the 13mm a few whacks with a mallet to get it going. Those bolts were very tight. Hope that helps. GK
Thread Tools | |
Display Modes | |
