19-08-2006, 06:40 AM | #1 | ||
I'm am going to be getting a compression test done on my car as it is using a bit of oil.
Its an AU2 XR6 VCT Does anybody know what numbers i should be looking for? Hopefully its ok.
: FALCON BEAUTIFUL : [COLOR=Gray] |
19-08-2006, 07:55 AM | #2 | ||
if you have a service book, like gregory's, etc then it should tell you in that. there are a lot of things that can affect the result, like how many km the car has done, how often it has been serviced, etc
19-08-2006, 09:20 AM | #3 | ||
Don't have a Gregory's, but was hoping someone might have.
The car has done 135K and has been serviced regularly but has had a trailer on it almost all of the time so it has worked.
19-08-2006, 09:43 AM | #4 | ||
SCALDED CAT
Hi Mate.... the numbers you should be looking for are....
100-650 kPa ( all cylinders need to be within 100 kPa of each other ) (must crank engine over several times before you achieve the correct numbers) If compression is low...pour a table spoon of oil into the sparkplug holes....if compression improve vastly....then it is your rings....if it doesnt improve with oil your looking at a broken ring or valves ethier burnt or valve seats....if two cylinders are just the problem it could indicate a simple head gasket problem. Anyway hope this helps you out....and good luck!!! :
"THE CAT IS BACK" |
19-08-2006, 03:33 PM | #5 | ||
the other thing that can cause oil usage without affecting compression is valve stem seals...of course if it is only these they are a lot easier to replace than rings or a head gasket
19-08-2006, 03:33 PM | #6 | ||
Cheers lads hoping on good results. Fingers crossed...
20-08-2006, 01:03 PM | #7 | |||
Thread Tools | |
Display Modes | |
