ThUmPeR
hey, ysterday i put in an EA sports cluster into my ED falcon. and now there is a weird light in the middle bottom of the dash that im not sure what it's for. i've put the oil presure sender in so it wont be that.
heres a drawing of what the light looks like. cheers troy
1994 ED Falcon ICE: 7" DVD BIG MTX sterio OTHER: 2.5" exuast, Pacemaker extractors K&N Flat pannel 20" Gianna wheels Dropped on Pedders BA Bonnet bulge clear indicators all round Full EL Ghia interior |
yep thats telling you that your coolent level is low. Time to top her up. Hope that helps.
#3 | |||
ThUmPeR
cheers
ThUmPeR
hey i just topped up the coolant and the light still comes on???
windsor user
obviously you dont have the coolant level sender in your radiator overflow bottle... so the light will be on constantly....
IMO remove the globe from your cluster.....too much trouble to wire it up |
V8 wannaabeee
i've been having that problem since over a week ago.... i top it up and it still does it !
.. i find it does it when i first start the car up (after leaving it for an hr.. then when it warms up when water rises it turns off) .. also happens when going around a bend :( i filled it up 4 days ago so meh.. i got a leak some where |
Steve
Or is it actually the wiper fluid level...?
Silver PJ Ranger XLT ...with goodies... |
ThUmPeR
thanks for the help guys.
cheers
You win again, gravity!!!
I found in my fairlane, that the float in the coolent level sender didn't actually float anymore...
The float is a magnet encased in plastic, so I just cable tied the float up against the sender's magnet and the light went off. Anyway, did the EA cluster go in easily? does the smartlock effect it? Is the oil pressure sender difficult to install? I want a sports cluster for my ED, but the smartlock ones are always more expensive...
1966 Fairlane 500 XL
#10 | |||
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
#11 | |||
ORSM FORD CRUSIERS
btw putting in the sensor is really eay you will need the coolant over flow bottle witha hole where the sensor goes and of coures the sensor the plug that connects to it is hidden under the overflow bottle itself tucked away plug it all up and you light will be acctually useful or you could do what i did and many others just remove the globe.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
#12 | |||
windsor user
#13 | |||
ORSM FORD CRUSIERS
crazy why don't they have one for the temp in the passengers that would be more useful .
#14 | ||
windsor user
heh...no idea......they have the ambient temp for outside on the EB2 on climate.....
#15 | ||
my ed xr6 has the washer flued level
#16 | ||
[ 5L ]
when my washer fluid is low that light comes on, also if the radiator level is low the same light comes on
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
#17 | ||
mine are 2 differant lights
#18 | ||
XR-6000 hit the nail on the head ........... I had exactly the same thing happen in my old EA when I put in the sports cluster ..... if the water level wasnt right in the washer bottle this light would appear ....... As too if the water level in the coolant bottle ........
#19 | ||
I have the same light coming up on my ed 5L but it's straight after I start it up and I read some where that it could also be a temp sensor on the engine causing the car to go into limp home mode. I only have 1st and 2nd gear and to get it to change into second I have to back off the throttle and it changes any one ha this or heard of it
Thread Tools | |
Display Modes | |
