Old 16-03-2007, 09:09 PM   #1
bentles
bentles's Avatar
Default melted alarm speaker
well my car has aftermarket alarm installed(90 years old by my estimate) and the alarm speaker was mounted on my wheel arch on exhaust side, and after getting extractors the speaker is now a very odd shape lol!
just wondering if i could pick up a new speaker and attach it to wires from the old one? i will also need to re-wire it as its going through my clutch cable hole which is going to be filled with a clutch cable soon....
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 09:11 PM   #2
frd_crzer
:D:D
frd_crzer's Avatar
u should be able to hook a new speaker up but u will have to re-wire it because the clutch cable will take up the whole hole
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 09:17 PM   #3
bentles
bentles's Avatar
thx for the quick reply! ill do it this weekend hopefully
Old 16-03-2007, 09:33 PM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
Ha ha, mine's like this too!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 09:48 PM   #5
frd_crzer
:D:D
frd_crzer's Avatar
haha but how can this happen i dont get it. I think it would be best to mount it on the other side of the engine bay where its less hotter lol
Cheers Grant
Old 16-03-2007, 09:52 PM   #6
bentles
bentles's Avatar
yeh but when it was mounted i didnt have extractors
Old 16-03-2007, 09:53 PM   #7
frd_crzer
:D:D
frd_crzer's Avatar
true true but i still think it will be better off on the other side
Cheers Grant
Old 16-03-2007, 09:59 PM   #8
bentles
bentles's Avatar
of course im not mounting it in the same spot lol that would be a little dim of me
Old 16-03-2007, 10:08 PM   #9
frd_crzer
:D:D
frd_crzer's Avatar
where are u goin to mount it
Cheers Grant
Old 16-03-2007, 10:16 PM   #10
bentles
bentles's Avatar
dont know yet ill see how i go i might remove my airbox and use a pod and put it near there
Old 16-03-2007, 10:29 PM   #11
gthofan
Gunna girlie-man
gthofan's Avatar
put it in front of the radiator, tucked under the support. when you wire it, run it where the cruise control servo is. there is a big hole through the firewall. (in the hiding spot to the left of the brake booster.)
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2007, 01:35 PM   #12
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
put it in the top left corner (when lookin at front of car)
i put mine along with my cruise control actuator in the top corner behind wheel arch against firewall but tucked away from sight. it was a little bugger to fit. but once in it wont get hot/wet or dirty.
ill try n get a photo to show u what i mean
brad
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual
Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter
BRADMAN is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2007, 02:10 PM   #13
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
has your alarm got the little key in it to turn it off, if it does and you cut the wires remember to turn it off cause it will go off when you cut the wires, worst alarms are genuine ford ones cause you cant turn them off and when you have to remove them and all you can do is wait until the backup battery dies
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
