#1 | |||
Back to Le Frenchy
I had to get an aftermarket CD player installed in the XR today since the factory stacker died last night and now when ever I put a CD in or turn the head unit off the aerial stays up. The only time it comes down now is when I turn the car off. Is there anyway to get it to work as it did with the factory unit again or am I going to have to get the factory unit put back in because having the aerial up shits me!
The 'Stihl' Man
![]() Join Date: Jan 2005
Can you get a switch for it? I know some e series have a switch, mainly ghias I think.
CRE.87V
wat head unit is it.....??? my pioneer didnt have a aerial wire so i got the aerial shaved and put one on the rear window....but yeh u can usually pull off the passenger kick panel in front of door....and hook up power , earth and switch...so u can put it up or down either on accessories or whenever keys are out....hoping this makes sense
#4 | ||||
Back to Le Frenchy
it's the head unit some have this wierd setup and I'm afraid there is nothing you can do apart from returning the headunit and geting a different brand you'll find if you turn it off first it will go down my kenwood goes down when on CD and i belive alpine do too i've been told Pioneer have the same problem as yopu have so avoid these too
The 'Stihl' Man
If you get a switch then its problem solved without changing your HU, Im sure an AU Ghia would have it, even an EA Ghia did!
Goodbye stock AU
Unfortunately aftermarket HU's won't do the job because the wire that activates your electric antenna is also designed to switch amplifiers on. so if you inserted a CD the HU would switch the amp off lol. A major oversight in HU design if you ask me!
EDIT: sorry looks like i was a bit too slow Last edited by curtleyw; 10-05-2007 at 09:26 PM. Reason: Too slow |
#8 | |||
Goodbye stock AU
Jeez that would peev you off hey!
Sorry for the bum steer, just all me mates have had the same problem. |
#10 | |||
Dirty ute club member
Im pretty sure your head unit would be able to do this. Take it back to the shop and have a whinge at them. I had to do that when mine wasnt connected at first. Had a whinge and its all sweet.
2000 AU2 XLS Daily 1992 Toyota Celsior: 4ltr quad cam goodness UZN106 Hilux: Absolute mongrel bitsa also with 4ltr quad cam goodness...Forced induction in the planning |
#11 | |||
#12 | |||
#13 | ||||
Back to Le Frenchy
#14 | |||
Nearly all aftermarket HU have a power anntena wire and an amp switch wire, even a couple of $180 cheap brand ones have it, curtleyw.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
#15 | |||
#16 | |||
Miami Pilot
#17 | ||
I stand corrected on the JVC but i do know this is true for Pioneer and I can remember when they were the best go figure!
#18 | ||||
Back to Le Frenchy
#19 | |||
Miami Pilot
#20 | |||
You can't stop the signal
Well if it turns out that it doesn't have the aerial trigger wire, i wrote a tech article on how to go about putting in a fully height adjustable switches using the amp trigger wire, click here
And for the record i've got a pioneer 7750 (about 4th best unit) from 2 years ago and it doesn't have an aerial wire cheers
#21 | ||
If its only going down when the cars turned off how can it be hocked up to the amp remote cable? if this was the case it should drop when the h/u is turned off.
#22 | ||||
Back to Le Frenchy
#23 | |||
Back to Le Frenchy
Well it's fixed and there was a wire on the back for the aerial. Why the moron that installed it didn't use it is beyond me, it had a bloody sticker on it saying that it is the power aerial wire!!!
#24 | |||
#25 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
#26 | ||
I posted a similar thread about a month ago.
I bought and had installed a Pioneer H/U, only to discover it doesn't have a proper aerial control. Aerial is up always when the H/U is operating. I haven't bothered chasing it any further with Jb Hifi. They wouldn't refund, and expected me to splash out another $150 or so on a higher end H/U instead. Audiotech can install a switch for me instead, which is a better option. |
#27 | |||
Powered by Rollin Motorsport Turbo Barra ED 4L
#28 | ||
I bought a pioneer deck (9650) for my AU and it had seperate Amp On wire and power antenna wire although if i connected the antenna wire the antenna would always go up when i turn the keys onto acc even if i was playing a CD, so i bought a switch from supercheap for about $4 and connected it to the power antenna and another acc position wire. Im no auto electrician but it works a treat, just have to flick the switch on wheneva i change back to the radio. Hope this helps!
