Old 04-03-2009, 06:18 PM   #1
Mont5.0
Mont5.0's Avatar
Default BA XR8 Air box dilema..
howdy all,
In the middle of fitting a BA XR8 pod style air box.(to fill the gap) Do i-
(a)- have a flanged plate to bolt upto old fixings, use small peice of hose and clamp off at each end or..
(b)- grind down sides of Mass Air Flow Sensor body and slip a 90mm silicon sleeve over it??
Opinions please. (also keep in mind i will not be going back to the original setup so returning to stock is not an option)
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 06:23 PM   #2
DW260
DW260's Avatar
I would personally go with a flange adaptor, silicone pipe and jubilee clamps.
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 06:25 PM   #3
Mont5.0
Mont5.0's Avatar
any reason why, over grinding down the housing??
Old 04-03-2009, 06:53 PM   #4
JC
Miami Pilot
JC's Avatar
Why do you need to grind anything? You only need one Pod filter adapter for an AU (around $25 from Autobarn, supercheap etc) and a 3" silicon joiner with 2 clamps - about $10 or $15. The BA Pod entry is 3.5", but the 3" joiner will stretch over it for a nice tight fit. You can also use a small section of bent 3" pipe and another silicon joiner like this:
Ford Performance Club ACT
Old 04-03-2009, 07:02 PM   #5
private9
www.TUFFCARPARTS.com
private9's Avatar
Or if you're feeling tight, instead of using a pod adapter, do what I did, and grab an EF Falcon airbox tube (sits inside the lid of an EF), cut it down, and bolt that to the MAF and use it as an adapter.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 07:24 PM   #6
Mont5.0
Mont5.0's Avatar
Thanks for the input folks. Nah i am not feeling tight- money has nothing to do with it. Was looking for a smoother look as all the joins and square bits really dont do it for me.
But thanks for all your suggestions.
Old 04-03-2009, 07:33 PM   #7
Mont5.0
Mont5.0's Avatar
JC did you notice any benifits from this style to the standard air box??
Old 04-03-2009, 08:30 PM   #8
JC
Miami Pilot
JC's Avatar
Well on mine, I had blown up 2 air boxes from LPG backfires - I had 3 backfires with the XR8 Pod without blowing the airbox to bits. Apart from that; nah, it filters the air.
Old 04-03-2009, 11:09 PM   #9
HLC
Audi S3
and looks cool!
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 11:16 PM   #10
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
I wouldnt bother grinding down the flange back to round, I'd just cut straight through it behind the flange then grind that little gusset down.
Then yeah one silicone/rubber joiner, small 3" manrel bent piece of stainless/aluminium pipe then another 3" joiner onto airbox and shes all done.
Will be looking into doing exactly that on the missus car soon.
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2009, 08:15 AM   #11
Mont5.0
Mont5.0's Avatar
take a look inside the MAF housing, there is not much to cut. thats why i thought grinding it back is a better idea, then with the slightly raised edge it measures externally 90mm- same as top of BA airbox lid.
Old 05-03-2009, 08:25 AM   #12
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Yeah thats why you use a 1mm cutting disc, it will do it no worries.
STREETBUILT RACING
Old 05-03-2009, 09:39 AM   #13
Cam
Stroking it...
Cam's Avatar
Will be interested how this pans out. I am looking for options for when I run a 90mm maf. Seems that this or a 03/04 cobra intake is the other option..
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2009, 11:16 PM   #14
Mont5.0
Mont5.0's Avatar
sorry guys forgot to post pics.....
Old 13-03-2009, 12:05 AM   #15
philstoj
philstoj's Avatar
This is what im doing soon and i have all the bits i need, but the bloody BA pod lid is only 3.5" and the silicon hose i got for the 90mm maf is 4".
What i need is one of those 4" power pipe pod lids as they are 4" diameter hole and it will all bolt up nice.
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2009, 12:19 AM   #16
Mont5.0
Mont5.0's Avatar
why not just run a shortened, 90mm joiner over the airbox lid (same length as the lid flange) and clamp the lot together? a thick joiner will take up at leats 5-7mm??
Old 21-05-2009, 09:18 PM   #17
philstoj
philstoj's Avatar
Yeah i might have to do something like that but no point yet till its in for a retune to suit the bigger maf, will keep you posted.
