Old 28-07-2005, 10:05 PM   #1
stockstandard
Default Bbm
Thought this might be interesting. One run with BBM locked in short runners, one run in long. Might help people decide if a BBM conversion is worth the effort or not.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2005, 10:09 PM   #2
AUII_Forte
AUII_Forte's Avatar
Bloody hell......I didn't think it made that much difference!
I'd say the BBM is where 90% of the power upgrade from the ED's 148kw to the EF's 157kw is.
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2005, 10:12 PM   #3
stockstandard
to the best of my knowledge, the ED (and previous) manifolds were about the same as the BBM on short, so the gains you get by swapping are the low end (where you do most of your driving).
Old 28-07-2005, 10:18 PM   #4
Rmyers
Does Steve have a car?
Rmyers's Avatar
I'd say that's not true, the BBM should make better low down power but up high it'd be about the same. Once the manifold switches to short runners above 3000, then the length of the runners compared to the ED manifold is the same, and in fact will technically be worse than the ED's as it has an open butterfly through the port that the air must travel around...
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2005, 10:18 PM   #5
AUII_Forte
AUII_Forte's Avatar
Thinking about that now, you're right! I'll crawl back under my rock now and shut up. lol.
See above comment :P
2.5" Exhaust
High Flow Cat
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
Old 28-07-2005, 10:34 PM   #6
sphell
sphell's Avatar
bloody interesting. Looking at that, you'd want the runners to swap over about 4000rpm not any earlier. IMO, I'll still stick to the good old ED manifold....never been a fan of the BBM.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2005, 11:08 PM   #7
neb
hibernating
neb's Avatar
interesting dyno chart... it does give a decent increase down low and midrange.. i can't really be bothered changing to it though :p
neb is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2005, 11:40 AM   #8
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
It does, 3800rpm.
Why would you say that, on a NA engine, it's a no brainer, the BBM gives a far wider powerband, without any drawbacks.
BTW, 'stockstandard', I did the same test on a dyno ages ago, and torque between 2500rpm-3500rpm had actually improved by approx 40nm.
Rick.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2005, 12:00 PM   #9
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
I've done the full conversion and have realized there is more power down low but up high i think it can be better....my max power output has dropped by a few odd kw...
174rwkW N/A I6 Kurucu Performance Enhanced...
Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph
Now With EL XR6 Engine & ECU & 3.7 Gears
Www.KurucuPerformance.Vze.Com
QUIKXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2005, 12:04 PM   #10
Sox
RIP...
Sox's Avatar
Why would you trade 2kw above 5000rpm, for 40nm of torque below 3800rpm though?
Rick.
Oval Everywhere...
Old 29-07-2005, 12:07 PM   #11
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
So we can do better down the quarter mile maybe....power is good for burnout already...whats 40nm gonna be good for down low?
Old 29-07-2005, 12:13 PM   #12
AUII_Forte
AUII_Forte's Avatar
Getting the car off the line maybe.
2.5" Exhaust
High Flow Cat
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
Old 29-07-2005, 12:21 PM   #13
Walkinshaw
Two > One
Walkinshaw's Avatar
i hope that is toungue in cheek.
1978 LTD - 408ci - 11.5@120.6mph -
2004 S4 - 4.2 - M6 - quattro -
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2005, 12:21 PM   #14
neb
hibernating
neb's Avatar
The main drawback about changing to bbm is that you also need to change ecu for it to work good... and then my little trip computer would be useless! But yeah it does provide a good increase all below 4000rpm.
What would also be good to see is an eb manifold compared against an ef/el manifold on the same car using the correct ecus
Old 29-07-2005, 12:31 PM   #15
stockstandard
Pretty close to the results I got (mines seems about 30NM).
Old 29-07-2005, 12:32 PM   #16
stockstandard
I would try it, but there its a bastard of a job on an EF...
Old 29-07-2005, 12:42 PM   #17
Sox
RIP...
Sox's Avatar
So I assume by that you only use your car at the drags?
You don't drive it on the road, but when you have to, you always have the revs above 5000rpm, correct?
Rick.
Oval Everywhere...
Old 29-07-2005, 12:46 PM   #18
Sox
RIP...
Sox's Avatar
Agreed, if it's not an easy conversion, then it's not for everyone, however if you're able to do it without complications, it's a no brainer.
Whilst I didn't do it back to back, I did do dyno runs with the only change being the BBM, a few weeks apart on the same dyno.
The log manifold curve looks essentially like the BBM when it's on short runners, which makes sense as the the runners are approx the same length.
The BBM's long runners are approx twice the length.
Rick.
Oval Everywhere...
Old 29-07-2005, 12:51 PM   #19
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
My conversion of the BBM involved changing the ecu and doing it the proper way...i am running an el xr6 ecu now...it is running the BBM switch and i have hooked up a noc sensor...b4 however i was running the standard eb/ed manifold with my ed xr6 ecu... the difference is nothing worth noticin...i have had it dynoed both ways on the same car...just gotta get the graphs scanned so i can post them up....cheers...
Old 29-07-2005, 01:04 PM   #20
EFFalcon
Last warning
EFFalcon's Avatar
the BBM goes hand in hand with an aftermarket ECU too.
where u can decide exactly where you want it to switch the runners for a smooth transition.
the feeling of my car when i ran with them undone was amazing, i know my ignition timing etc is set for it, but still a fair change.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 29-07-2005, 01:29 PM   #21
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
heh, i'm running around in my EB at the moment with the BBM locked on short runners...
for some reason the switch isnt switching. gotta love cable ties ;)
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2005, 01:35 PM   #22
EA2BA
PM me if you want
EA2BA's Avatar
If you have tied shut that is long runners
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2005, 02:15 PM   #23
stockstandard
I think when you have it all setup you will notice the advantage. If you get in an EF/EL/AU and disable the BBM you really notice the lack guts down low.
Old 29-07-2005, 02:30 PM   #24
neb
hibernating
neb's Avatar
I'm just thinking when disabling the bbm to switch.. could the lack of power down low also just be due to the fuel mapping being wrong when its not switched? That would make sense wouldn't it.
One thing I also dislike about the bbm is that the intake pipe needs to be alot longer and curves in a 180 degree bend... the eb intake pipe is shorter and less bends.. which seems a bit better
Old 29-07-2005, 02:47 PM   #25
stockstandard
No doubt tuning will change the way it feels. Just saying if you dont notice the difference a BBM makes then it isnt working as it should. Whether or not the extra power is worth the effort is another matter. Considering the amount of time engines spend <3800 compeared to >3800 I think it is worthwhile even though it wont help you win any dyno comps or improve your 1/4.
I tend to agree with you with the intake setup. Although it does flow more than enough, I think ford could have done a much better setup by swapping the battery and airbox over. Would have a nice straight pipe from the TB to the box then.
Old 29-07-2005, 02:59 PM   #26
EA2BA
PM me if you want
EA2BA's Avatar
Heat from the exhaust would be an issue, I think face the top half of the intake the other way would be a better solution , has any one tried this for room, ignoring throttle linkage etc (these can be worked around)
Old 29-07-2005, 03:02 PM   #27
neb
hibernating
neb's Avatar
I've always thought that would be a good idea dellboy... I can't understand why they faced it that way and made the intake loop around.. throttlebody should be facing towards the passenger side of the car.
Old 29-07-2005, 03:08 PM   #28
EA2BA
PM me if you want
EA2BA's Avatar
If someone has done it, will save me checking, otherwise one day sooner then later I will test the theory cause I want to
I think it will get a little messy on the runner switching side of things to change, but anyway.
Old 10-09-2005, 08:16 PM   #29
eafalcon
Default Where is it
Where is the knock sensor fitted on the EF/EL?
Do u need it if u do the BBM conversion to an EA, if so how and where do you fit it????? I mean physically not electrically.
I am running an EL ecu at the moment.
eafalcon is offline   Reply With Quote Multi-Quote with this Post
