Old 04-02-2011, 08:49 AM   #1
james22
With da Warlords
james22's Avatar
Default Xcal 3 Q's
Hi all.
Just a couple of questions about the Xcal 3 and the au.
Firstly, does the data logging work on the AU? I've heard conflicting reports on this.
And secondly, with the xcal 3, can you modify the tune afterwards? (after it leaves the shop/dyno) Spark, fuel, idle etc
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2011, 09:20 AM   #2
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
I cant comment on the AU's mate but yes your tuner CAN leave some parameters open for you to adjust ..Diff ratio/tyre size/fan speed/trans shift/idle rpm's/ etc...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2011, 09:47 AM   #3
james22
With da Warlords
james22's Avatar
Yeah not so worried about that stuff, but I wouldn't mind being able to adjust the tune itself (timing, fuel, rev limit etc) Between datalogging, borrowing a dyno & wideband 02 sensor, I'd like to be able to fine tune parameters myself
Windsor Warlords
AU III XR-8220
Old 04-02-2011, 10:13 AM   #4
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
The adjustments if left available will not be something that will enable you to make fine accurate adjustments i.e spark will be able to be adjusted on an AU as global spark, so you can add or subtract some spark, but you will not be able to target individual rpm or laod points.
Fuel adjustment is for WOT at all rpm
Idle speed can be adjusted
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2011, 01:59 PM   #5
james22
With da Warlords
james22's Avatar
Cheers, and does anybody know about the datalogging side of it? Have heard the some au's are a bit problematic in this regard
Windsor Warlords
AU III XR-8220
Old 10-04-2011, 10:44 AM   #6
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Default Re: Xcal 3 Q's
had any luck yet james?
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 11:44 AM   #7
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
I cant get mine to Datalog any more than a minute, but when the car was last tuned Simon was able to data log a few runs with no problems at all. He was saying most AU's wont allow data logging............I called Herrods a while back in regards to this issue and basically got blown of with them saying its a AU thing.............Cant help but feeling a little ripped!!!!!!
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 07:44 PM   #8
sly
Sly like a G6
sly's Avatar
Mention AU to Herrods & they can't get off the phone quick enough.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 09:27 PM   #9
CRAIGAU3220
Cat be Still !!!
Yes, the only way they would get of the phone quicker would be if i asked for a couple of hundred bucks back for a feature (Datalogging)they promote but don't deliver.
Old 12-04-2011, 02:16 AM   #10
old fordnut
too many fords
old fordnut's Avatar
why not use a sniper tune?
Daily driver 1: [COLOR=Indigo] 2010 FG XR6 Turbo 50th Anniversary, BPR CAI, Plazmaman turbo pipe.
Daily driver 2: Nissan gq patrol
Project 1: XP ute, 351W, c4, 9inch
Project 2: XBGS sedan, sunburnt orange and vinyl, original 4spd, 302C.
old fordnut is offline   Reply With Quote Multi-Quote with this Post
