Old 25-10-2011, 10:32 PM   #1
ZXTC
Default Help: Alternator bolt head stripped ---
Hi All
Replacing a fautly alternator on my series 1 Au S/wagon. All going well till that last 10mm bolt that goes from the power steer pump bracket. Different people tried different socket sets etc till the head rounded We also tried the top 13mm bolt head with no luck also.
Anyway any ideas on how to remove? Was thinking of just cutting the head off but not sure if the bolt will just pull out? Banging on a smaller socket but no reall space to swing a hammer? Cut the bracket?
Cheers Mick
ZXTC is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2011, 11:12 PM   #2
Default Re: Help: Alternator bolt head stripped ---
Breaker bar and Irwin boly extractor from Bunnings:
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 25-10-2011, 11:33 PM   #3
SSD-85
A more available method may be vice-grips. I used a set to remove an air-ratcheted sump bung...
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2011, 12:20 PM   #4
mik
mik's Avatar
if it`s rounded sometimes you can hammer on the next size down socket.
Old 26-10-2011, 03:00 PM   #5
Davo3460
Just a little trick try tightening it a little first to break the bond
Davo3460 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2011, 01:11 AM   #6
ZXTC
Hi All
Got the bugger off
Used an Irwin bolt remover socket. Came off really easy.
This was after a 'professional' auto electrician tried and said it's stuck and to call in the bolt remover specialist!
Cheers Mick
