Old 18-05-2010, 07:28 AM   #61
prydey
Rob
prydey's Avatar
Originally Posted by fairmont1998
Just an update. Had the 30 000km service on Saturday and the dealer loaded the newest TCM software into the car. The shunt is completely gone now.
what dealer? i notice wayne phillis @ christies has already had a few mentions in this thread. i use wayne phillis reynella for anything i need and they are awesome.
thanks for bumping this thread up. i bought a LS focus on the weekend for my inlaws and it seems to have this same problem.
the other time i noticed almost the same sort of 'shunt' was at 100 - 110 in 4th. almost like a really noticeable lockup of the converter. not sure if its related at all.
20focus05 - you still at rowell and searle? its interesting you mention the TPS could be faulty. the one i bought, when you go to take off, has not much reaction to the first bit of accelerater travel and then suddenly you are off. can this be adjusted? are they 'fly by wire'?
prydey is online now   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 05:55 PM   #62
20focus05
I wanna XR5
20focus05's Avatar
Hey Prydey I have only just left them last week. I have a 15km drive now instead of 100
LS are drive by wire and I dont think TPS is adjustable.
I have also now heard about the software updates which are fixing the problem.
The only real problem we have seen with the focus is soloniod failures.
we had one guy who had codes retrived and it says something like valvebody issue but all it is is one of the shift soloniods. he was qouted $2500 to replace valvebody,
we did it for about $800 to replace soloniods, I also dismantled valvebody and replaced gaskets because the code that came up can relate to a gasket blowout.
I have driven an auto LS and though the same about accel.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 07:14 PM   #63
prydey
Rob
prydey's Avatar
cheers.
if left, can the 'shunt' get worse, or become a bigger issue. as you may be aware the car is my inlaws and i didn't mention it to them because i doubt they'd even notice.
Old 20-05-2010, 07:56 PM   #64
fairmont1998
fairmont1998's Avatar
Jarvis Ford Norwood look after my two cars. I've been very happy with their service department.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2010, 09:30 AM   #65
DeKa
Originally Posted by 20focus05
SO SERVICE IT EVERY 20,000 or 12 MONTHS.
What do you recommend be actually carried out in an auto transmission service for a Focus, so I can make sure the right things are done?
DeKa is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2010, 05:21 PM   #66
20focus05
I wanna XR5
20focus05's Avatar
These transmissions are the same as the mazda 323, protge, 3, 6. Ford call them a different name.
Remove pan
remove filter
replace filter
replace pan with new gasket
fill it up, sometimes they will have a buzz after a refill sounds like cavatation(have never found the cause)
We over come this by over filling give it a short run then remove oil back to level.
There are no adjustments required to bands, all preset.
These Transmissions rarely have major issues, most problems we have seen are related to solonoids.
Old 10-01-2013, 10:58 AM   #67
T3ts50
T3ts50's Avatar
Default Re: 2008 Zetec auto trouble.
Hi guys, I also have an auto LS Focus which seems to be have a few issues.
My focus mainly drives on the freeway, and recently, when I start to slow down or get off the freeway, it doesnt know what gear it wants to be in and usually hold onto 2nd. When it does eventually change gears it does make a clunking sound. Would anyone know what the issue might be?
T3ts50 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2013, 05:04 PM   #68
marg99
If you have done 80,000 + klm check the CV joints in the drive shaft especially when slow cornering they make a noise if worn
