Old 15-08-2014, 07:00 PM   #1
red_hotxr6
red_hotxr6's Avatar
Default Au xr6 series 3
Just bought an au xr6, when its cold, i have to turn the key at least 3 times before it will start,and on all 3 goes there is a definite backfire out the exhaust, once the car is going its ok, however even though i have changed the spark plugs, as the old bosch super 8 looked as old as the hills, its still doing it.
Anything else i should look at..
red_hotxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2014, 07:24 PM   #2
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
Default Re: Au xr6 series 3
If the plugs were old, then the leads and other stuff is likely to be old, so a good start might be to give it a full service.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2014, 07:33 PM   #3
red_hotxr6
red_hotxr6's Avatar
The leads look a lot better than the spark plugs..blue in color, big 8.0mm written on them, but i will check it out on monday, and where they are i cant change them without going to a lot of trouble...
Old 15-08-2014, 07:36 PM   #4
Sox
RIP...
Sox's Avatar
Fair enough, though it still may simply be a service (lack of) issue.
To begin any real fault finding, the service side of things should be up to scratch anyhow.
Oval Everywhere...
Old 15-08-2014, 07:42 PM   #5
red_hotxr6
red_hotxr6's Avatar
you could probably be right, maybe the coil needs changing, or the injectors need cleaning, who knows..i think he was one of these guys that just drove the thing and that was it..
Old 15-08-2014, 07:53 PM   #6
Sox
RIP...
Sox's Avatar
Yep, I would start by giving it a once over with oil change, filters, etc.
Then grabbing a scan tool from Ebay, downloading Forscan, and going for your life scanning for issues.
http://www.ebay.com.au/itm/ELM327-V1...item3a929ebb03
Oval Everywhere...
Old 15-08-2014, 07:59 PM   #7
red_hotxr6
red_hotxr6's Avatar
As i have just bought the car i immediately booked it in to my mechanics, to do a rwc on it, even though the guy gave me one...a few things dont seem right..and that is monday, so yeah
Old 19-08-2014, 06:20 PM   #8
david lee
my xr6-3 once had a similar issue plugs and leads
david lee is online now   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 06:31 PM   #9
red_hotxr6
red_hotxr6's Avatar
There were a few things wrong, main ones was the rotors were bad as, brake pads right down, rear tyres balding/lack of tread...which indicates misuse of the car, however i fixed all of them up today, all brand new, brand new brake switch, replace the number plate lights, and a wheel alignment, different car..oh new plugs, and new leads to be put in...i just want to live in the thing now.
Old 19-08-2014, 08:36 PM   #10
Polyal
The 'Stihl' Man
Polyal's Avatar
Don't know about you blokes but I always give a new car a full service to get things all sorted..start with the little things
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is online now   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 08:38 PM   #11
mcfly94
mcfly94's Avatar
agreed full major service when you buy a used car
oil and filter
air filter
leads and plugs
fuel filter
trans service
check diff oil level
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 08:56 PM   #12
red_hotxr6
red_hotxr6's Avatar
Yup that is a must, like my plugs and leads were so old yet the oils were new as...cant get at the leads so the mechanic is going to do that..and get the injectors cleaned at the same time..
Old 26-08-2014, 06:21 PM   #13
red_hotxr6
red_hotxr6's Avatar
Another quickie, after driving on the highway for 20 mins, picked my son up from school, and had to crawl, stop start to get home, about 3 klms, took 20 mins, the temperature gauge went to hot about 1/2 a klm from home, immediately put the heater on hot full bore...what i want to know is how to check the thermo fans, is there a way to check and see if they are operating?? And yes, after the car cooled down, i checked everything,plenty of water, coolant, all the fuses are ok.
Took it for an 20 min run its ok...
Old 26-08-2014, 06:41 PM   #14
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
The thermo fans should start up as soon as you turn on the A/C.
MINE- AUII Forte
Old 26-08-2014, 06:52 PM   #15
red_hotxr6
red_hotxr6's Avatar
a/c does not work..compressor has seized..looking for one at the mo..2nd hand of course
Old 31-08-2014, 08:34 AM   #16
red_hotxr6
red_hotxr6's Avatar
just got JAX to fix my rear rotors and brake pads, they said the fan plug was diconnected..and found a good working au compressor for $88..so ready for summer soon
