Old 31-03-2022, 08:47 AM   #1
sprintman1
Default 17” Falcon alloys
Wheel Size site says there were 17 x 7.5 ET42 alloys on BA Falcons. Every set I look at are 17 x 8. Do these 7.5 width rims actually exist?
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 10:15 AM   #2
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: 17” Falcon alloys
Yes i believe so. More likely to be fitted on Ghia's and non-XR models that had 17's.
Those models usually had 225 wide tyres, and not the 245's the XR's used. So they had a smaller rim to match.
Old 31-03-2022, 10:17 AM   #3
Vesper Martini
Vesper Martini's Avatar
I assume you are looking at aftermarket Rims? what size tyre are you planning on running?
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 10:20 AM   #4
Fordman
Fordman's Avatar
My factory 17 rim says 17X8J36.5 on it and i have 235/45/r17 tyre.
Guessing you are trying to get 7.5 to get a dished rim or something?
Fordman is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 02:38 PM   #5
sprintman1
Factory, not aftermarket.
Old 31-03-2022, 02:39 PM   #6
sprintman1
215/55R17 tyre. 7.5 max width.
Old 31-03-2022, 03:07 PM   #7
Fordman
Fordman's Avatar
Ok i think I get it now.
So we know BA XR6 rims aren't the 7.5 size.
So we could only consider other factory 17s on the BA. e.g. (Fairmont, Fairmont Ghia, SR and Futura)
Also slightly unrelated appears to be a Terry rim of that size that existed on SZ Terry's
https://www.jeffersonfordparts.com.a...assembly~14169
Old 31-03-2022, 03:11 PM   #8
T3rminator
T3rminator's Avatar
Wow. I had always assumed they were 7.5s. My pov pack 5.4L 3v XT came with the factory 17" rims, I have one spare in the boot, and just checked and its 8 width.
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 03:12 PM   #9
sprintman1
Yes I wondered about using a set of Territory rims. The only difference I could see on Wheel Size was a 0.1mm difference in bore size.
Old 31-03-2022, 03:29 PM   #10
Vesper Martini
are these tyres you already have?
Im not expert on Falcon wheels but I believe a factory XR6 17" alloy takes a 235/45R17
the factory steelies were 16" which took a 215 tyre
Old 31-03-2022, 03:30 PM   #11
Vesper Martini
different offset, and they took 235 wide tyres too
Old 31-03-2022, 04:54 PM   #12
arm79
arm79's Avatar
Yes, can confirm my BF Ghia and Dad's old BA Fairlane had 225/50 on 7.5" wide rims.
His current BF XR6 has 8" wide rims. But standard fitment is 235/45, not 245...
225/50 are rather expensive rubber given their odd size. But I run 235/45 on my Ghia rims without hassle.
Old 31-03-2022, 05:26 PM   #13
sprintman1
Off daughters car. Will be 225/55/17 on the rear.
Old 31-03-2022, 05:51 PM   #14
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
That size tyre works well on 17x7.5” wheels, I ran them on my trailer.
Just use Territory alloys (17x7.5 ET36.5mm) they fit Falcons, although a bit heavier (i.e. stronger). Much easier to find than Falcon wheels that size.
PS. Don’t believe everything you read on Wheel Size. I’m sceptical any Falcon alloy was ever ET42.
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
