Old 28-04-2006, 10:22 AM   #1
Mr Cube
Mr Cube's Avatar
Default Strange noise - Engine or Trans. who knows???
Driving the ute to work last couple of mornings I have noticed a sound like air being squeezed out of a small hole coming from the front of the car at around 3,000rpm, just before it changes gears.
Its a XR6 auto - trans was last serviced 20,000kms I thought it may have been the gears grinding or slipping/
First morning I thought what the.. listened to it and after the car had warmed up it seemed to not be there.
This morning the ute was warm and I noticed it didn't matter what speed I was doing under med to hard accelerator at around 3000 is made the noise for about 400rpm.
It is when the car is changing up gears and it doesn't matter from gear to gear it just does it..
Anyone else had a similar experience.. As Im not sure if its the engine or the trans Im also not sure where else to post on FF so I thought I would start wit h the fellow AU folk.
Have you got an FPV or XR6/8 and live in the ACT or surrounding area? Come and check out the FPV & XR Owners Club of ACT
AUI VCT:
To date - Big brake upgrade, Koni and Kings all round, 2.5 cat back ready for replacing, 19" again ready for replacing.
Planned - Too much now I got the baby back.
Mr Cube is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2006, 11:58 AM   #2
JC
Miami Pilot
JC's Avatar
Yep - I've had a similar noise. Mine was the start of an exhaust leak (broken manifold gasket), and it only got worse from there, to the point where it was a constant ticking, not just the occasional flutter of air.
Ford Performance Club ACT
Old 28-04-2006, 12:37 PM   #3
Mr Cube
Mr Cube's Avatar
cost much to get it fixed.. I was thinking of getting some headers for the Ute anyways, so while they are there get them to check this out also.. Would Fred at Tugg do that job?
AUI VCT:
Old 28-04-2006, 06:33 PM   #4
JC
Miami Pilot
JC's Avatar
He would. And if it is the transmission, the auto trans place is right next door. I reckon it's a broken exhaust manifold which should be replaced with Pacemaker 4499s or 4480s (comps) as a matter of safety. *wink*.
Old 28-04-2006, 06:56 PM   #5
Baboon_AU
Baboon_AU's Avatar
yes...for safety reasons i fitted Pacemaker 4499's too *wink*.
just also check engine bay for any hoses that have come loose or came off eg, the PCV valve and so on..
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
