sparky
i put my 88 ea falcon 5 speed (on lpg) on the dyno ,and it only put out 73kw. i couldnt beleive it. it goes so well on the road.can any one give me any tips on get more kilowatts
Last warning
tune, exhaust, extractors, snorkle, new filter.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
![]() Join Date: Jan 2005
Sounds CFI, convert to MPI. As John said exhaust, extractors, some sort of CAI will make it go good, i'd also recommend a cam it's definetely the best mod i've done to my car.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
![]() Join Date: Dec 2004
And a major service (so that the tune is worthwhile)
Just add boost!
#6 | |||
Slide Baby Slide
:the_finge You want more inches...........STROKE IT!!! :the_finge Mr Super Skid-Man |
here's an idea, use the EF/EL Variable manifold, and an EL computer for ignition and manifold control. Also a set of extractors and an EF Cam wouldnt go astray (rumours are that the EF profile is very similar to the ED XR6). Of course if your is a 3.3, abandon all hope of cheap easy power and find an EF engine complete... good for ~ 100rwkw in an auto, probably ~ 105-115 in a manual.
Should yield some impressive results, epecially if you find a way to use all of the supposed 100+ octane of lpg... cya Ben that said, is it possible to use the old 3.3 crank in an EF engine, to allow some major revs (decent power without stressing gearboxes with too much extra torque)? |
OzECruisers Treasurer
Get A new Car
Check that your accelerator cable is opening the throttle all the way.
Boost Cruisin'
hey dude how exactly do u go about using BBM off an EF/EL i have access to one from my EF XR6 wreak i wanted to use it but didn't know exactly how, ne instrutions would be helpfull
1988 EA falcon, 20inch dark agents, cyprus blue, ED XR front, full EF fairmont interior conversion, built AU motor with modded BA turbo pistons, AiResearch T04, Snort manifold & 4inch dump, 50mm Synapse external gate, custom stainless 3inch exhaust & cooler piping, Synapse BOV, SMT8 piggy back, lowered on king sl's and ultima shocks, full noleathane bushings |
manifold apparently bolts on, you just need something to switch the manifold over, and a computer mapped to the manifold would be better as well (hence EL computer, suited to manifold, injectors, and the distributor ignition).
apparently they give an improvement just on their own, with an rpm switch triggering the vaccum line that switches the manifold over, but the fuel/ignition isnt perfect. LPG is probably a different story though. make sure you ask some other people though, I havent done this, my car already came with it. cya Ben |
#12 | ||
Girrrrr!!!
My first EA had 80hp, which I think it roughly the same KW you got...
My cat had collapsed.
Falcon EF XR6 in Heritage Green Heritage green, isn't that a fence paint? |
#13 | |||
FG G6ET RAPIDTuned, RAPID V1 IC, F6 turbo.
FG2 GT RAPIDTuned on E85, Xforce exhaust. |
#14 | ||
Hmmmmm
or just drop in an ED XR 6 engine like me.....goes like nothin else!!!.....big step up from the 3.9cfi's....trust me!
