Old 03-05-2010, 05:18 PM   #1
rosebush
rosebush's Avatar
Default DTE & Fuel Gauge reading empty with full tank
My DTE and fuel guage keeps reading empty even after half filling the tank. Its like its stuck on Zero and beeps all the time.
Im assuming it has something to do with removing the boot carpet as it started straight after we did this.
This has happened in the past a couple of years ago (Again from removing the carpet) but then just one day fixed itself????
Any ideas please on where to start? Thanks
rosebush is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2010, 05:23 PM   #2
GS608
Welcome to the world of Ford electronics..mine quite often doesn't register when i fill it up and keeps going with the low range and fuel light, has only happened when i put $20 or so in it though.
Old 03-05-2010, 05:24 PM   #3
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
But in this day & age would $20 of fuel even move the gauge up at all?
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2010, 05:28 PM   #4
rosebush
rosebush's Avatar
I put in $40 (Half tank about) but still didnt move surly thats enough to do do something??
Old 03-05-2010, 05:29 PM   #5
frd906
Noticed mine does the same thing, my dte reads at 80 when it shows quarter of a tank, which it usually registers at 200, cluster must be on its way out
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2010, 05:39 PM   #6
rosebush
rosebush's Avatar
Mine registered at Zero at all times....It must have something to do with removing the carpet, is there a switch or something that could of come loose in the boot? This is what happened last time...Just dont know how it fixed itself...
Old 04-05-2010, 02:56 AM   #7
Mechan1k
Mechan1k's Avatar
Sounds like a dodgy connection to your fuel sender ... a dodgy sender ... or a dodgy float.
At least yours is say it is empty.
Mind at one point said I had 200km left to go .... but was actually dead empty ... I managed to roll into a servo ... only to find the servo didn't have an LPG pump ... spewing.
Thread Tools
Display Modes
