Old 01-11-2006, 09:59 PM   #1
UltraLowEd
Default Couple Questions
ok i have a couple of questions
Will el side mirrors fit on an ed?
Will el door handles fit on my ed?
Will el fairmont ghia door trims fit on my ed?
last question will an xr6 au engine fit in my car?
UltraLowEd is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2006, 10:02 PM   #2
BLSTIC
dunno
dunno
dunno
YES!!! needs grinding of sump though, but from all reports it is well worth the effort. you kinda need a computer that will run coil packs and that flash manifold though, unless you put your old manifold and dizzy on...
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2006, 10:03 PM   #3
UltraLowEd
thankx, i can get 1 for 800 bucks off ebay with 155,000 ks on it
Old 01-11-2006, 10:06 PM   #4
BLSTIC
shouldnt have told me that, now I want it... but you're safe for now, I don't have $800... and putting it into an EF needs way more effort anyway.
actually the door stuff may fit onto your car, apparently the whole E-Series range had very similar doors, at least externally. You will notice that the EF/L doors have a strange speaker mould that follows the dash line too, it may cause problems.
Old 01-11-2006, 10:11 PM   #5
Damo
yes to all your questions Jared except maybe the mirrors.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2006, 10:13 PM   #6
-jjM-
-jjM-'s Avatar
mirros will fit, seen it done from ea to ed, might need to drill a new hole for one of the screws thow
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2006, 10:14 PM   #7
snypereb
[EBGLT]
snypereb's Avatar
They all fit including the mirrors you just need to drill holes have another look on lowxr he has them!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2006, 10:16 PM   #8
EDXR6T
Mirrors will fit all you need to do is use the ED loom plug's for the electric's to work and drill one hole. Apart from that strait swap.
Door handle's strait swap no stuffing around. Unless you have a door triger thing that make's the interior light's come on.(found in monty's.? and ghia's) You have to grind the mounting tab's a little for the nut's to grab the thread on the door handles.or just get rid of them.
Door trim will fit with minor mod's. Im not to sure on them but now of ppl that have done this mod.
Yes grind the front rib's on the sump and it will fit no prob's.
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2006, 10:21 PM   #9
UltraLowEd
Thankx people
Old 01-11-2006, 10:24 PM   #10
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Here is a thread about the door trims and it has some photos in it as well.
Click link:- http://www.fordforums.com.au/showthr...ght=door+trims
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2006, 12:02 AM   #11
NudgE^SIKBRO
Never late with a V8
NudgE^SIKBRO's Avatar
Mirrors FIT... Holes need to be drilled... i have EF Mirrors on my 89 Fairlane and they look a treat although if you do it...
A: use Tiawaneese mirrors... believe it or not the lugs that the screws are longer and stronger
B: You NEED EF/EL Exterior weather strips (EA-D are shorter and leave a hole)
C: Cut the EF Plugs and use EA-D ones
My Rides
(Daily)2004 Explorer V8 Limited
(Work) 2014 Kenworth K200 Aerodyne
(Classic) 1969 Mini K, 1340, twin SU's
The beginning is near!!!
Body by Ford. Soul by NudgE
NudgE^SIKBRO is offline   Reply With Quote Multi-Quote with this Post
