Old 14-11-2006, 08:08 PM   #1
melbzetec
Old enough to know better
melbzetec's Avatar
Default EGR tube on LR Focus
Question for the more technical.
Does the Australian delivered LR Focus Zetec have a EGR (exhaust gas recirculation) tube?
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 08:54 PM   #2
Piotr
Non-Regular Member
Yes it does.
"Zetec drops the variable valve timing that has been used on the Contour for internal EGR, in favor of a less expensive conventional EGR valve that's adequate for Low-Emissions Vehicle (LEV) standards."
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 10:04 PM   #3
melbzetec
melbzetec's Avatar
Thanks Piotr. Where is that quote from?. The reason I ask is I have a Ford Racing long tube header coming from the states (eventually!) and it has a modified EGR tube to suit the zetec engine. But that of course is the Zetec engine in the U.S., thus my question about Australian delivery
Old 15-11-2006, 06:18 PM   #4
simonr
Focus Rookie
simonr's Avatar
Are you Removing your cat?
Those long tube headers designed for use without a cat.. i think?
04' Panther Black Focus Zetec
Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters
simonr is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 08:06 PM   #5
WRC1AB
WRC1AB
WRC1AB's Avatar
I have just bought a focussport race header with flex pipe and it had 3 holes in it.
2 at the top and 1 down where the 4 tubes join into 1.
If your racing the car you don't need the cat.
If your not, the best thing to do is put a hiflow cat straight after the flex pipe (I got the metal cat).
What thay did to my car was just relocat the oxygen sensor from the old header further down where the tubes go from 4 into 1.
There were no other sensors on the std header.
The other 2 holes where closed of with proper size nuts with copper washers.
The car runs fine, just make sure when the new header is on there is at least 5-15mm gap between you header and the bottom of your sump. you don't want heat near you engine oil.
My header is ceramic coated so it doesn't heat up as much.
Nick.
[ :eclipsee_ : :eclipsee_ LR Focus
WRC1AB is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 09:56 PM   #6
melbzetec
melbzetec's Avatar
No Simon, will be installing a new cat. This is a new long tube header for the Zetec that has only been available over the last 6 or so months that is designed to bolt onto a cat.
The system is a 4-2-1 header originally from the Focus SVT (ST170), modified by Ford Racing Parts to bolt onto the Zetec engine.It is stainless steel and will be ceramic coated. (Which is part of the reason for the delay) A picture of the uncoated header is currently in my avatar. Then a Random Technology hi flow sports cat is connected that fits under the engine rather than in front (The OEM SVT cat sits underneath). This will then be bolted to a 2.25" stainless flexpipe, which will then bolt to my existing 2.25" Herrod stainless catback. An O2 harness allows the O2 sensors to be extended to match up with the new sensor positions
In the states, this is currently regarded as THE header upgrade, giving measurable increases in both power and torque.
My plan is to dyno the car after installation and compare to most recent dyno chart, so I will be able to share the figures.
Once completed, my system will be modified from air inlet to tailpipe, only retaining original throttle body and intake manifold, and MAF sensor.
Old 15-11-2006, 10:16 PM   #7
simonr
Focus Rookie
simonr's Avatar
Awesome.. How much and where you ordering it from!?
Old 15-11-2006, 10:21 PM   #8
simonr
Focus Rookie
simonr's Avatar
http://www.mcnewsautomotive.com/Prod...id=M-9430-ZX3L
is that it ??
Old 15-11-2006, 10:37 PM   #9
melbzetec
melbzetec's Avatar
That's the one. Getting it all from McNews (after being stuffed around by CFM)
Rough cost around $1500 including header, cat, and flexpipe and freight.
My current cat is cactus, and Ford wanted $1300 for just the part. So it made sense to bite the bullet
Old 15-11-2006, 10:43 PM   #10
simonr
Focus Rookie
simonr's Avatar
too bad you live in melbourne.. and that im broke at the moment!!
we could of split shipping costs!
Good luck.. Im looking forward to see the results!
Old 16-11-2006, 12:23 AM   #11
zetec
Zoom Zoom
zetec's Avatar
I'm looking forward to beating the "results" at small Ford Sunday 2007...
2012 Mazda3 MPS
Old 16-11-2006, 09:36 AM   #12
melbzetec
melbzetec's Avatar
You are a very cheeky puppy Mr Matt. I think I will adopt the "walk quietly and carry a big stick" approach.
Boys and girls, next years Small Ford Sunday will be worth buying tickets for. There will be white hot competition between Matt and I, as we polish our cars virtually back to bare metal................and then "Best Focus" will be taken out by someone else!!!!!
Old 16-11-2006, 09:38 AM   #13
photn
AFF Post NAZI
photn's Avatar
BAHAHAHAHAHA lol like who lol.......
Lol Your Funny!
