Old 24-01-2007, 11:20 AM   #1
MrFlibbles
ill have a beer milkshake
MrFlibbles's Avatar
Default ef xr6 will not idle, any ideas?
my EF XR6 will not run/idle at anything below 1000rpm if you hold the throttle open a bit it does run(above 1000 rpm), drove the car yesterday all was good.
misses got in to drive it today bang no idle!
anyone have an idea on what it is, or how to trace what might be causing the problem?
current cars:
2001 AU SII XR6 manual
2001 Nissan Patrol
1969 Isuzu Florian
1976 Chev luv (really its just a rebadged Isuzu!)
1980 Isuzu KB 4x4
MrFlibbles is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 01:01 PM   #2
FairmontEL
Driftin shopping trolleys
FairmontEL's Avatar
so it completely stalls under 1000rpm? my bet is the (TPS)throttle positioning system i think thats wat it stands. it failed on a car ive driven had to brake and accelerate at the same time just to get it home!
VZ Calais 5.7ltr cammed, stalled, and the rest.
04 BA XR6T ute
FairmontEL is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 01:15 PM   #3
10secondET
one day
10secondET's Avatar
probly stuffed computer not sending the ics signal to the ics motor
i had this happin try the ics but prob wont fix it
XY GTHO MOCK
406 cleveland grout filled, pavtek alloy girdle
scat 4340 crank, scat h beam rods 2000 series bolts
CHI cnc 2v heads
comp 308r solid roller camshaft
torque power single plane manifold
950 quickfuel race carb
pro trans c10 with transbrake
5500 tce converter
3.89 diff gears
10secondET is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 01:20 PM   #4
fiery
fiery's Avatar
I had a similar sounding issue with mine about a year and half ago. It was something within the computer not functioning correctly anymore and throwing it all out of whack (but not constantly).
From memory it wasn't a huge amount to fix (pretty sure it was around $100 or so).
Good luck
Originally Posted by MNM96
Quit wingeing, drink more and grow a Butt! Its un Australian not to be the correct size to fit the seat of a Falcon!
fiery is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 01:29 PM   #5
DNKPWR
DNKPWR's Avatar
Its prob the ecu at fault it u wanna fix it it will cost you just over $300...
i know this cause, i got mine fixed last week at Automotive service solutions. Check there web site out there are a few in different states!
They are pretty much just a ECU specialist..
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 02:36 PM   #6
10secondET
one day
10secondET's Avatar
why pay $300 if you get any eseries computer they all have the ics driver ic
inside remove it and fit it to your xr computer it will need to be desoldered
and then resoldered into the xr computer now its the chip closest to the plug
on the right hand side when looking into computer when holding the plug up
its an easy job if you have any soldering knolage i have done this and it works fine it cost me an ea mpi computer and 20 mins
XY GTHO MOCK
CHI cnc 2v heads
5500 tce converter
3.89 diff gears
Old 24-01-2007, 03:53 PM   #7
daz82
In the family since 1996
daz82's Avatar
whats ur fuel usage like? blowing any smoke? if so could be ur map sensor. if not then could be ur ecu or tps, oh and congrats on the stanza, i had one once with a 2.4L stroker in it, f*#ckin quick little beast.
daz82 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 04:53 PM   #8
MrFlibbles
MrFlibbles's Avatar
cheers daz the stanza is a beast! (not roadworthy yet tho!)
fuel usage has been normal and havent noticed any smoke of any sort from the car, it just decided this morning to bugger up my day!
thanks guys for the input, will hopefully have a trade customer of mine have a look at it tommorrow with his wizz bang computer, will let you know what happens!
current cars:
2001 Nissan Patrol
1969 Isuzu Florian
1980 Isuzu KB 4x4
Old 25-01-2007, 08:05 PM   #9
MrFlibbles
MrFlibbles's Avatar
been on a computer diagnosis thing today and have been told it is the cmp??? and possibly the map sensor too.
only one question what the heck is a cmp??
current cars:
2001 Nissan Patrol
1969 Isuzu Florian
1980 Isuzu KB 4x4
Old 25-01-2007, 09:00 PM   #10
efgiar
rofl copter
efgiar's Avatar
change the map sensor and see how u go. the cmp could be a random code, did he clear and recheck?
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 11:44 PM   #11
MrFlibbles
MrFlibbles's Avatar
will try to get a map sensor asap and try it but being a long weekend i might not be up to it!
current cars:
2001 Nissan Patrol
1969 Isuzu Florian
1980 Isuzu KB 4x4
