Old 11-04-2005, 09:34 PM   #1
EB6
apprentice grease monkey
EB6's Avatar
Default bbm manifold woes.
ok i know this has been discussed many times but i can find the specific info im after.
im runnin my bbm manifold using the standard eb com, i have a ford vac switch but what i want to know is does the switch need the power to it to change the bands or does the power need to be taken from it to switch the bands when rpm is increasing. im either buyin a shift light setup to give it power and run it in a v8 mode so i can have the power goin to it lower than 3g to make the switch or to get a relay which works off signals (neg side of coil) and switches by taking the power away, need to know which way to go. or any other ideas ya may have.
EB6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2005, 09:49 PM   #2
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
jaycar have a rev switch kit. only thing is, you dont get the best fuel/ignition timing as the el ecu. u could use a unichip to do them changes though.....
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2005, 07:18 AM   #3
8pAc
RDP #181
8pAc's Avatar
The ford vacum switch willl only work if you are using an eecV modile, it has a 12 volt feed and links back to the ecu. the ecu then switchs the runners at 3800 rpm and alters timing and fuel maps
8pAc is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2005, 09:05 PM   #4
EB6
EB6's Avatar
got a uni chip so thats the fuel curves taken care of, found out old toyotas have a whole bunch of vac lines that shift with 12v power so all good.
Old 13-04-2005, 09:16 PM   #5
needturbo6
needturbo6's Avatar
i thought unchips could also adjust ignition? are you definitly sure unchip only does fuel?
