Old 03-04-2007, 09:00 PM   #31
Interceptor
HSV - I just ate one!
Interceptor's Avatar
before i bought my sprint i almost bought a rebodied XE ESP, but at least the ESP had some history to it.....
T-boned in the mid 80's and rebuilt by DJR with a brand new, unstamped shell that was supposedly supplied to DJR by ford australia after dickie took his field trip through the scenery at bathurst...... he had the paperwork to back it up, and DJR confirmed it, but i couldnt afford to buy it and being it back to A1 condition
Interceptor is online now   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 09:17 PM   #32
EF_Frmnt
EF_Frmnt's Avatar
the police and vicroads/rta/qld transport are not the only ones allowed to stamp engine numbers. Often when fresh engines get sent to dealerships for warranty claims they come bare and must be stamped by the dealership with the old engine number, the old one being ground off as they often remanufacture the engines.
An you will also find some aftermarket blocks come bare and you must add your own engine numbers.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 09:44 PM   #33
irsa76
Snoopping
irsa76's Avatar
You would find that if it was a proper rebody, the chassis number will have a different prefix. I've seen new shells in parts books and they all state that they are stamped replacement. I would be interested to see what a stolen vehicle report says about the chassis number on this one.
Oh yeah, compliance plate swaps aren't hard. I've personally fitted a few, legally, for various importers.
irsa76 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 10:12 PM   #34
peedee
peedee's Avatar
To restamp a body number on a valiant you need to grind it off the right inner guard and restamp it, which makes it a charger of any model with a r/t compliance plate, or in the case of a friend of mine his right side was hit hard his body number no longer matches the compliance plate which states it is a 1974 XL charger (base model), but the ammended number on the new inner guard states it is a 1978 4 door regal se sedan, which is right,both because both have been noted on the registration papers, if the car ever went out of rego and the records not available it would not be registerable under any means
peedee is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 08:36 AM   #35
LukeGT
Melbourne, Victoria
LukeGT's Avatar
Most of the rebody's done after the first few years of the cars life are into second hand shells which already have a VIN number.
The main reason for rebody's of these cars is because damage or rust which the owner believes is too difficult to repair. It is generally a Falcon / Fairmont shell that they use and I would not expect the shell to be stolen because they are cheap enough to buy.
When a GT is stolen and rebodied with a different GT's ID (from a rusted out car etc) then it is not usually advertised as a rebody because the owners is trying to pass it off as an original, or they would not have bothered.
LukeGT is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 12:04 PM   #36
The G6ET Spot
He says that the interior is all there,but the problem with it is that it has a blank steering column and a blank console as well.Steering column is also the wrong colour.Seems to be a bits and pieces car to me.Might be genine tags, but no motor and box and different body there no way that it's a genuine GT as he advertises it.
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 10:58 PM   #37
Linz
*SILVER SERVICE PILOT*
Tech Writer: Recognition for the technical writers of AFF - Issue reason: For his technical submissions. Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with good, solid advice.
Originally Posted by Bill_R
He was going to "RETORE" it - that says it all.
HAHA...why stop there?? RETORE...WAIST...REGESTED The guy can't speel for nuts!!!!! :
Linz is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 11:23 PM   #38
ZEDAYE
20 INCH 100 SPOKES
ZEDAYE's Avatar
To rebody a GT just takes a good panel beater. Remove the shock tower that has the stamped numbers, then refit into 2nd car.
ZEDAYE is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 11:34 PM   #39
1970galaxie
Fat 460
1970galaxie's Avatar
There is a lot more to a GT body than just the shock tower number.
1963 1/2 Galaxie Fastback. Rangoon Red. 427/4 speed.
1970 Galaxie Sportsroof. Matt black/purple scallops. 460/C6.
1972 XA GT Sedan. Monza Red. 351C/4 speed.
2003 BA XR8 Ute. Blood Orange. 5.4/5 speed.
2006 Territory Turbo. Silhouette. 4.0/6 speed auto.
1970galaxie is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 11:58 PM   #40
4Vman
4Vman's Avatar
If that's all the effort they went to id pick it in a second.. There's far more to a 54H bodyshell than just some numbers stamped...
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 09:42 AM   #41
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
You might pass it off to someone who has no idea what they are looking at, but anyoe who knows a thing or two about GTs will pick it.
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 10:50 AM   #42
KBBossedXR
GetBlown or GetBlown Away
We do have to give the guy credit for being honest about it being rebodied as there are so many dodgy people out there today that wouldnt say anything and hope someone buys it as original. My thoughts are this is not the only rebodied GT out there thats for sure, people with the money will spend as much as needed and there is no limit we all know that now days (XW PHASE 1 $750,000 for sale at the moment). If you have that sort of money and are willing to spend whats needed no one would know otherwise. Having said all this i dont agree with it but i dont know what i would do if i was driving my XR GT and some idiot crashed into me and wrote it off and i have my replica sitting there but no more GT, what would you guys do keeping in mind it wasnt your fault and your GT is no longer here anymore.
KBBossedXR is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 04:17 PM   #43
Tony xa
Streetrides panel & paint
Tony xa's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Tonys qualified advice on paint and panel is always very good
Yeah your right there at least hes being honest about the car but I wouldn't have thought he was realistic but I must be wrong as hes getting bids and the price is getting pretty damn high for what it is But like i said I must be wrong .
Surely people are not this hard up on getting these cars that they are willing to convence themselfs that its worth their while but like I have said twice before I must be wrong
Tony xa is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 01:48 PM   #44
4Vman
4Vman's Avatar
I guess that depends on how the rebody is identified.
Being "honest" about a rebody (an illegally done one) is a bit like admitting to a crime, (or at the very least being aware of one and not reporting it).
Rebody's are illegal if restamped with the GT's numbers and can't legally/technically be registered or sold unless they get inspected and get police numbers stamped on them...
