05-04-2007, 01:51 PM | #1 | ||
someone told me it's better to keep the engine running idle for 2 mins to heat the oil before run on road, said higher oil temperature benefit to the lubricating effect.
but other said the engine can rapidly heat itself to the required temperature. which one is correct? thanks! |
05-04-2007, 02:02 PM | #2 | ||
Tricolore Tard
Jump in.
Start up. Flog the crap out of it out of the car park. It soon warms up in about a min or so Chris
05-04-2007, 03:59 PM | #3 | |||
Mr Focus
You should warm up your car even for a few mins.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. |
05-04-2007, 04:02 PM | #4 | ||
yeah i wouldnt flod the crap out of it if its been sitting there overnight.. i always in the morning start my car up leave it running for bout 5 mins til im ready to go and yeah.. i dont flog it til its at the normal temp in between 1/4 and 1/2..
i dont think its any good to just start up and start driving. |
05-04-2007, 04:52 PM | #5 | ||
Non-Regular Member
I drive it with revs between 2k to 3k while its cold and only when its at nominal temperature do I rev it to 6.
05-04-2007, 05:07 PM | #6 | ||
Very enthusiastic driver aren't you, Piotr.
I always warm up my car in the morning for 1 or 2 minutes. Here's what I normally do... -Start the car and let it idle -Put on shoes -Drive out |
05-04-2007, 05:26 PM | #7 | ||
Tricolore Tard
My goodness...
You dont need that for all the new engines. Mine is warm after 30 secs of normal driving Get in start up and go easy as Old engines, yes warm them up for a couple mins
05-04-2007, 07:31 PM | #8 | ||
Yeah, get in, idle for ten seconds to get the oil up to pressure then drive off and take it easy for the first couple of minutes. Your gearbox or diff oil isn't going to get warm just sitting in the driveway idling.
05-04-2007, 07:33 PM | #9 | ||
It's actually worse for an engine to sit idling for a few mins than for it to be driven.
05-04-2007, 07:39 PM | #10 | ||
Anyone care to bring fact to this discussion?
I would be interested in the answer too. |
05-04-2007, 10:08 PM | #11 | ||
Zoom Zoom
It goes harder when it's cold. I run harder off the lights when it's cold.
That's fact enough for me
2012 Mazda3 MPS
05-04-2007, 10:21 PM | #12 | ||
2006 Focus LX Hatch
Once the gauge starts to move, you're ok to go. I usually keep the revs down though until it gets to about 1/4
05-04-2007, 10:24 PM | #13 | |||
2006 Focus LX Hatch
05-04-2007, 10:55 PM | #14 | ||
2007 Ford Focus Zetec
You're only meant to let the engine idle for about 15 seconds to let the oil circulate around the engine, but don't flog the engine while its still cold.
You'll do more damage to your gearbox, than you would to your engine. |
05-04-2007, 11:08 PM | #15 | ||
LPG > You
My procedure...
Get in, start car. Wait for temperature gauge to move from stone cold, turn on A/C, drive away normally. After its popped up a bit... it takes not even a minute to go all the way to normal temp. Process usually takes 1 - 3 minutes.
LPG Lovers Association President & Member #1. : |
06-04-2007, 10:51 AM | #16 | ||
I've read in owners manuals for different makes of cars 1) let engine warm up for 20 seconds 2) don't idle engine for more than 5 minutes.
In the Fez, I let it warm up until the rpm's settle down to normal idle (750 - 800), usually 20 or 30 seconds, then drive off. |
06-04-2007, 11:12 AM | #17 | ||
Critical Thinker
I always warm up the car in the mornings for a minute or so. Only because the car is a bit sluggish until its at operating temperature.
But I never over rev the engine when cold. most revs is about 3k while still cold. I just take it easy until car is at operating temp.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
06-04-2007, 12:47 PM | #18 | ||
AFF Post NAZI
i turn car on. close house door. get in car drive to end of driveway. close gate. then drive like i normally do.
when i get to end of street. let first gear hit 6k just to get things going!
06-04-2007, 07:47 PM | #19 | |||
07-04-2007, 12:49 AM | #20 | ||
I think its more to do with oil pressure.
07-04-2007, 09:49 AM | #21 | ||
It's mainly because new engines are EFi (better fuel metering) and we now have multigrade oils.
The reason to "warm up" the car by idling is because in the past there was only single grade oils that did not work wwhen it is cold. Also some would warm up the engine on a carbied vehicle if it is a pig to drive when cold. |
07-04-2007, 02:44 PM | #22 | ||
Letting the car idle does not let the gearbox oil to heat up.
Your better off driving it sedately until operating temprature. |
08-04-2007, 10:03 AM | #23 | |||
Guess my car is using SAE 5w-30 |
08-04-2007, 07:30 PM | #24 | ||
I hope all you guys revving the crap out of your cars have it paid off before you need a new car... Oh oh I think I'm starting to sound like my old man.
08-04-2007, 10:16 PM | #25 | ||
5W-30 is multigrade.
10-04-2007, 08:21 PM | #26 | |||
Zoom Zoom
2012 Mazda3 MPS
11-04-2007, 09:47 AM | #27 | ||
Drive sedately like BlackLS said neither overly long idle time or thrash from cold are great for an engine.
Be mechanicaly sypathetic and use common sense |
