Old 28-04-2005, 02:46 PM   #1
Sundeep
Sundeep's Avatar
Unhappy Heater Core
I think my heater core has had it :( The car's been ****ing coolant from a factory drain hole on the firewall since the engine went back in, now the water is pouring and when I go up hills the water comes out from the passenger side footwell!!!
It also started steaming from the demister vents hardcore lol, I thought it was on fire for sec, then it all started pouring out of the dash so much that I had to pull out the stereo and move the microfueller that's mounted there. From the outside it would've looked like someone was having sex in the car lol.
So anyways, it's my heater core right? I've never seen anything like it so I wouldn't know.
How much is just the core new? Is it hard to replace? Am I better off changing the heater box?
Cheers guys,
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 02:56 PM   #2
spope
spope's Avatar
Ah yeah, I'd say your heater core is stuffed. If your windows are fogging up even with the demister on, then there is fluid in the heater box.
A new heater core from Ford is worth around $100, and you've got to pull the heater box out to change it.
It's not really worth stuffing around with a 2nd hand core, new one isn't that expensive, and it is a pain to change, so better off doing it once only.
I'd sell you the c/c conversion stuff back, but it's already in my car.
It's a good excuse also to vacuum out the heater box and ditch all the leaves that have accumulated.
In the meantime, it's easy enough to bypass the heater core, presumably you are still running the cfi heater pipe at the rear? Just unhook the hose with the heater tap on it and put it on the end of that pipe. Mine was like that for 4 months.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 03:00 PM   #3
Sundeep
Sundeep's Avatar
So it a heater box out job? I'll save it for when the manifold comes out again and I'll pull the dash out at the same time. It'll take like 10 minutes that way lol.
I hope it's all simple :S
Sundeep
Old 28-04-2005, 03:54 PM   #4
InitialD
Low and Loud
InitialD's Avatar
Yep you need a new heaterbox sunny, My old one did that just before Gunns and I fitted my Climate Control. Also check under your passenger side carpet, I bet there is water and dampness there aswell.
Ive got a excellent condition Heaterbox for you if you need it :P it works Grouse
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 03:55 PM   #5
InitialD
Low and Loud
InitialD's Avatar
Ohh and you can change it easily with the Manifold in, took me no time. Only 5 nuts or so.
Old 28-04-2005, 07:45 PM   #6
Damo
A mate at work has the exact same problem as you Sunny, he wants me to help him fix it. 8-) Let us know how you go, and whether it's easy or not.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 08:00 PM   #7
Sundeep
Sundeep's Avatar
Won't be easy so I'm going to bypass it like Steve reckons.
I drove for 3 minutes today, and the heater box automatically set the climate in the car to "tropical humidity + 10% vision on the windscreen". Makes driving fun, stopped and filled coolant twice in 7km.
I need a daily.
Sundeep
Old 28-04-2005, 10:43 PM   #8
sphell
sphell's Avatar
I've got a heater box for sale if you want...lol ;)
sphell is offline   Reply With Quote Multi-Quote with this Post
