Old 14-05-2007, 05:44 PM   #1
sneaky
sneaky's Avatar
Default knock in rear suspension - AU3 SR
my wife pointed out a 'knock' in the rear suspension of our AU3 SR (stock) the other day. it seems to be more noticeable over slow bumps.
just wondering if this could be a simple case of tightening the nuts on the rear shock tower? or any other suggestions.
i'll stick my head over it and under it on the weekend to see what i can see see see, but was hoping for an easy answer
cheers
-tim
sneaky is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 05:50 PM   #2
The Monty
Just slidin'
The Monty's Avatar
Mine keep coming loose, I have been back to JAX twice in the last 8 months, they just tighten it and it gets good again. Was told it was a quite common problem.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 14-05-2007, 06:01 PM   #3
sneaky
sneaky's Avatar
cool, might get some lock-tight through the week. should i be looking under the car or in the boot?
don't want to crawl under car for hours to find it in the boot, and don't want to pull carpet out of boot to find out its underneath..
-tim
Old 14-05-2007, 06:20 PM   #4
The Monty
Just slidin'
The Monty's Avatar
Im not sure, I just drive mine to Jax, and they fix it up for me for free, I got it lowered through them, so the look after me.
Old 14-05-2007, 07:05 PM   #5
sneaky
sneaky's Avatar
cheers..
wonder if ford would fix mine for free they put it together in the factory...
doesn't matter, just something else for me to get dirty doing on the weekend
-tim
Old 14-05-2007, 08:35 PM   #6
Sledgehammer
Sledgehammer's Avatar
It might be the dreaded AU rear shock mount that may need replacing. Its a common problem.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 04:10 PM   #7
xr8 007
xr8 007's Avatar
yeap, rear shock mounts. happened to me too. i herd heaps of slight knocks here and there. Took it to Pedders for a 12 point safety check and was advised of the mounts needing to be replaced.
He also told me it was a common problem among au;s
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 05:03 PM   #8
FTE217
T3/Sprint8
FTE217's Avatar
That's the prob for sure.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 15-05-2007, 08:45 PM   #9
RG
Back to Le Frenchy
RG's Avatar
That's if it has IRS.
Old 15-05-2007, 08:51 PM   #10
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
if its irs than that will definitly be the problem. i had the same problem about $99 each from ford. And you will get dirty putting them in
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 09:14 PM   #11
Dark Horse
_Oo===oO_
Dark Horse's Avatar
I doubt it's got an IRS setup, but interesting to note the findings nevertheless. How many k's since the shocks were last changed on the SR Pete?
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 10:38 PM   #12
FTE217
T3/Sprint8
FTE217's Avatar
ooops yer my bad, live axle, can be shock, lower mount loose or upper.
Can be upper or lower control arm bushes,sway bar D's worn.
Daily Macan GTS
Old 15-05-2007, 11:21 PM   #13
phildee
phildee's Avatar
the lower rear shock mounts can make a bad knocking noise if not done up extremely tight. Has happened to mine a couple times. Had to tighten them as much as i possibly could to stop it.
phildee is offline   Reply With Quote Multi-Quote with this Post
