Old 15-05-2007, 09:12 PM   #1
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Default transmission problems
Hey guys, i did a search but couldn't really find much.
My auto ute seems to be stuck in 3rd gear which i would assume means its in limp home mode but also its having trouble changing up through the gears, it only just started yesterday afternoon so i thought maybe one of the electrical plugs got loosened. Doesn't seem to be the case, i put the ute up on the ramps and gave the contacts a clean, still is doing the same thing.
According to the service book, it had a trans service not that long ago so i'm stumped
any ideas would be appreciated
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 09:19 PM   #2
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Solenoids? S5 in particular?
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 09:26 PM   #3
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
can they suddenly just go?
Old 15-05-2007, 09:36 PM   #4
just me
AU2 XR8
solenoids and all things electrical in the trans can fail at anytime the s5 usually will develop a bump or harsh shift into second gear particularly when the trans is hot before it totally dies the best way to tell whats wrong is to take the car some where that you can get a computer scan to see what the problem is dont worry about driving the car you wont damage the trans limp home mode is designed to prevent that keep us posted
cheers
just me is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 10:48 PM   #5
peterban
AULTD
peterban's Avatar
My old DC LTD died suddenly one day with no indication of a fault.
It would still go in reverse 1st and 3rd only but wouldn't select 2nd and 4th.
It turned out to be one of the bands in the auto and I had to have it rebuilt.
If your speed sensor is faulty it will also cause limp home mode
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 10:11 AM   #6
LOWAU
___________
LOWAU's Avatar
How many kms has it done? I would service it again just to make sure it has been done, while they are there they can inspect/test the shift solenoids as well.
Does your auto slip a little when cold? Mine does so when my mechanic serviced it he put an additive in to rejuvinate the rubber seals, but all this does is just hide the fact that I need a full rebuild :(
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 10:15 AM   #7
FGII-XR6
FGII-XR6's Avatar
also check all the electrical connections
Old 16-05-2007, 07:35 PM   #8
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
its done 156000 kays and have never had any problem at all with it, going to take it down to ford tomorrow, see what they say...if its gonna cost too much i'll seriously consider a manual conversion.
Gotta see the bright side of things huh?
