Old 22-06-2007, 10:15 AM   #1
tickfordguy
TICKFORDGUY
Default chrome door handles
thinking of getting sum chrome door handles for my au 3 how hard are they to swap over does the door trim have to come off is there any little tricks to them
MY CAR
tickfordguy is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 11:49 AM   #2
private9
www.TUFFCARPARTS.com
private9's Avatar
I had mine out a few months ago. I can't quite remember if you have to remove the trims to get the handle completely out, but I don't think you do.
Either way, quite easy to do and you should be able to do all 4 doors in under an hour or so I would think.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 12:37 PM   #3
FGII-XR6
FGII-XR6's Avatar
no need to remove trims easy job
Old 22-06-2007, 12:42 PM   #4
Oo_xrsx_oO
t i c k f o r d
Oo_xrsx_oO's Avatar
how's this done without removing the trims?
AUIII XR6 VCT
Liquid Silver / Manual / Leather / Momo Wheel & Shifter / Premium Sound / Lovells Superlows / Koni Reds / T3 Pursuit Rims / Pacemaker 4499s / 2.5 Inch Exhaust
Oo_xrsx_oO is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 12:45 PM   #5
private9
private9's Avatar
I'm pretty sure handles just come out seperately.
Old 22-06-2007, 12:53 PM   #6
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
nah you will have to remove the trims to be able to play around with the spring and watnot. Because the actual handle assembly itself is riveted to the door, so you just replace the handle itself (get me?) i found that to do this the trim had to be pulled off or else its really difficult to get to the spring. The first one i did took about half an hour (call me a slow learner) then the other 3 took another half hour total.
i also inserted a chrome gear selector surround at the same time. it really livens up the interior and makes it feel a little younger.
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 01:44 PM   #7
Oo_xrsx_oO
t i c k f o r d
Oo_xrsx_oO's Avatar
Wasn't only series 1 that had the rivets where the whole unit (handle and housing) needs to be replaced rather than just the single chrome handle?
AUIII XR6 VCT
Old 22-06-2007, 02:01 PM   #8
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
Yeah series one had the handle and backing plate rivited to the door, to one series one you need to just change the handle.
I have falkeen's tech article on it, i'll post it here when i find it
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 02:05 PM   #9
au^dude
au^dude's Avatar
I think that the AU1 were riveted to the door, cause thats how mine were. But as far as i know the S2/3 were done with screws.
au^dude is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 02:07 PM   #10
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
serious?!? bloody hell they really made it hard for us series one drivers eh!! still only took an hour all up.
Old 22-06-2007, 02:09 PM   #11
au^dude
au^dude's Avatar
Yeah they made everything hard for us.....Brakes, door handles whats next..
Old 22-06-2007, 02:09 PM   #12
superroo
superroo's Avatar
AU chrome handle installation
Author - Falkeen
Here is my procedure on replacing the standard AU series 1 interior door handles with the chrome T-Series items.
I replaced all four handles (because the original handles didnt look right with the new black interior), this cost $100 for the set, but most people just do the two front doors. Personal choice, but in my opinion it looks much better having things all matching nicely.
T-Series chrome door handle
Part No. ER F 22600 B - R/H side
.............. ER F 22601 B - L/H side
Removing the old handle
This is the main issue with this modification. On the Series 1 models the handle is riveted onto the inner skin of the door (only applies to series 1 as the handle plates were riveted to the door skin, whereas series2/3 were just screwed so can simply be replaced).
Notice the rivets on either side of the handle
After removing the door trim, you will find the door handle as above. The way i got around not being able to take the handle off because of the rivets, i only replaced the handle itself, leaving the original backing plate attached to the door.
To remove the handle, slide the white plastic shaft that the handle pivots off then disconnect it from the wire cable. The handle will now come free from the backing plate.
NOTE: The plastic shaft has a split in it to prevent it from sliding up and out, you can push this in from the side so that it slides out but i didn't bother as they were going to be discarded anyway.
The handle itself will now be free from the backing plate as shown
Installing The New Handle
First of all, the backing plate needs to be removed from the chrome handle as it is not needed. Pushing the split in on the plastic pin can be done easily as you can do it through the hole in the back of the mounting plate.
NOTE: Take note of how the spring is positioned in relation to everything as this will help when re-installing.
This is the fiddliest bit of the lot, re-assembling the handle onto the door (but when you think its either this or trying to remove the rivets and then re-fitting the entire handle, it doesnt feel so bad).
NOTE: Keep telling yourself this throughout this step as it helps confidence and morale.
FIRSTLY, re-attach the wire cable onto the handle! CANT BE DONE LATER (really hurts after finally getting the thing assembled then finding this).
Position the spring onto the mounting plate on the door and then carefully slide the new handle on, keeping the spring as much in place as possible (this is the hardest bit!), then slide the new plastic pin down through the holes and spring which holds everything in place.
JOB DONE!
You can now re-fit the door trim and it should look much better.
New handle installed (missing power window switch plate in this shot. doh!).
Now you have no excuses!
Falkeen
Old 22-06-2007, 02:15 PM   #13
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
down to a T
Old 22-06-2007, 02:41 PM   #14
au^dude
au^dude's Avatar
Should send that to Casper or whoever handles the aufalcon web site, So they could put is as a technical document.
Old 22-06-2007, 02:43 PM   #15
Oo_xrsx_oO
t i c k f o r d
Oo_xrsx_oO's Avatar
So on a series II/III its as simple as undoing the screws, replace the whole unit and re-attach the wire cable? No fiddling with the springs etc?
AUIII XR6 VCT
Old 22-06-2007, 03:03 PM   #16
MRJUCY
Fordless
MRJUCY's Avatar
I haven't checked if it still is but it was on there, I would have assumed it still was.
I've never understood why people call them T-series door handles tho they were on the Ghias & LWB models but they weren't on TE50s I added them to mine tho.
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
