#31 | |||
It's a TORQUE MONSTER............................... |
#32 | ||
so fitting this bigger pod filter has given you more performance then your 2.5 exhaust did? time for some dyno runs once its all set up i think
#33 | ||
![]() Join Date: Dec 2004
Sounds great that you can get so much of a difference from simply swapping a pod. Did you take a "before" dyno run showing tractive effort? Because it would be great to see the "after" dyno results and compare the differences.
#34 | |||
But once again it's a TORQUE MONSTER!!!!!!!!!!!!!!!!!!!!!!!!!! Cheers.. |
#35 | ||
Here are the dimensions of the conical filter.......
RE-0810 Product Specifications Product Style: Round Tapered Universal Air Filter Base Outside Diameter: 6 in (152 mm) Flange Inside Diameter: 3 in (76 mm) Flange Length: 1.75 in (44 mm) Flange Type: Centered Height: 9 in (229 mm) Top Outside Diameter: 4.625 in (117 mm) Top Style: Rubber Top Material/Finish: None Filter Re-Oiling Amount: 1.92 oz (57 ml) Flanges: 1 Inner Wire: No Weight: 2 lb (0.9 kg) Product Box Length: 11 in (279 mm) Product Box Width: 6.5 in (165 mm) Product Box Height: 6.5 in (165 mm) cheers..... |
#36 | ||
right
#37 | ||
Team Urinal Cake Racing
lol TORQUE MONSTER!!!!! hahahha probrably the extra induction noise your hearing.
Oh also go drive around on a hot day and see hoe much heat soak you get :P |
#38 | ||
GT= The Gamble,The Legend
Seemingly having a larger surface pod filter benefits your car being a 6 cylinder, would there be advantages for the v8 windsors then?
Fred Gibson -Dump the clutch from a standing start, you could wheelspin the car with smoke bellowing of the car 1st, 2nd gear and wouldnt stop until 3rd gear. Howard Marsden -They were at time rated supposedly as the fastest 4 door production car in the world. Bill Bourke - Part of the GT that changed the auto industry of australia, i would say one word, exciting it added excitement to the industry. -GTHO P3 |
#39 | |||
Anyway, it's good to know that people get satisfaction from modifying their cars, no matter what the mod is. I think I'd display a similar reaction if I slotted a 514 between the rails, but good on you for your enthusiasm. PS, I'm not a fan of that flange diameter. Nor the length. |
#40 | ||||
Back to Le Frenchy
#41 | ||
ED xr8 5.0l
I picked up about .15 of sec in the 1/4 when i went to a bigger pod and a home made alloy/ply heat shield here is a pic.
ED xr8, STD 5.0l short block AFR165 alloy heads 11.92 @ 113.5mph N/A 10.98 @ 122.2mph 100hp nos 377 RWHP @ 5900rpm N/A No longer bottle fed, now with boost 9.67 @ 144 mph on 22psi |
#42 | ||
looks nice
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
#43 | ||
Sleeping Beast
Mmmmmmmmmm Im almost convinced to go ahead with the pod filter rather than a K&N or BMC filter for the standard air box.
#44 | |||
What's green is gold
![]() Thanks, i needed that...
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
#45 | ||
If your car responds well to small modifications like that maybe you should try some hardcore stuff it'll run 12's easy NA.
Nah kidding, I reckon the difference you feel is in throttle response. Sundeep |
#46 | |||
it has a bit better response and looks way better than that black of a pipe that closes round to about 1 1/2"
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
#47 | |||
Sleeping Beast
Location: whyalla SA Good to see a member on here from my hometown ![]() |
#48 | ||
I'd change the spark plugs, they can give good power increases as well.
#49 | ||
Don't forget the leads Rob-dog
#50 | |||
Sleeping Beast
#51 | ||
Flange leads are the best brand. They're large bore, pink coloured. Bursons sell them.
#52 | ||
Flange leads come in multiple different fittings too. Loose, Mid, and Tight
Heritage Green EL Ghia Black AUII XR8 Ute |
#53 | ||
Some of them last for a lot more kms than lesser brands. There's a niche brand, I've forgotten their name but the code number for the leads is BU77-53CK5. They come with extra hardy plug sockets. The leads are brown.
