Old 31-05-2005, 11:28 AM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default AU BCM - What does it control?
Guys, just want to know what the BCM controls?
AFAIK, it's power windows and cruise control. What else does it control?
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 12:35 PM   #2
au-steve
fully *** turboooo
au-steve's Avatar
everything but the engine and trans?
AU1 Forte
178.6rwkw @ 5 psi
Highflowed T03, Intercooled
Full comp insurance :nutsycuck
au-steve is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 07:29 PM   #3
russellw
russellw's Avatar
The BEM controls:
LOW SERIES MODELS
• Manual control of illuminated entry and exit delay
• Manual boot release with security time out and speed dependant disable
• Remote central locking with hazard acknowledgment
• Manual central locking
• Remote drivers door lock /unlock
• Panic alarm
• Key in lock warning horn/hazard
• Anti-Theft warning LED
• Remote control for illuminated entry
• Remote boot/ tailgate release with hazard acknowledgment
• Door unlocked horn/hazard warning
• Automatic door relock timer
• Transponder challenge/response immobilisation
• Heated backlight timer
• Front intermittent wiper timer with fixed dwell, wipe on take off
• Front wipe after wash timer with fixed number of wipes
• Diagnostic capability of inputs, outputs and trouble codes
• Diagnostic self test
• Battery saver for dome, boot and glovebox lamps
• Power window supply control with key off
HIGH SERIES MODELS
The additional functions to the low series are as follows:
• Front intermittent wiper dwell timer with variable dwell and speed dependency
• Front washer motor control
• Instrument cluster illumination (LCD & Graphics) control
• Power antenna control
• Automatic headlamp switch off action with manual override
• Headlamp warning chime, headlamps on, ignition off.
Mid series vehicles use a high series BEM with a number of the functions disabled.
Examples are headlamp delay, single dome lamp circuit, no front washer control.
Russ
Old 01-06-2005, 10:17 AM   #4
TheSneakiness
Adapt or perish...
Originally Posted by russellw
The BEM controls:
LOW SERIES MODELS
• Panic alarm
Thanks Russ, now, I'd assume that my ute would have some/most of those functions, therefore I assume I'd have a BEM module in the ute.
Sounds stupid, but I'm actually learning something new here.
Carless
