05-12-2007, 12:59 PM | #1 | ||
Hello,
I would appreciate any advice how to fix my problem. I have Ford Focus SE 2000 (no fog lights). A couple of days ago the parking lamps and instrument cluster lighting went out suddenly when I pressed remote luggage compartment release button. Side lights (left, right), brake lamps, back-up lamps, and hazard flasher are working fine. When I press brake pedal, the instrument cluster lights up normally. First, I changed brake lamps because I thought they burned down. It happened before. Then I checked fuses - they looked fine. Then I replaced headlight switch, but it didn't help. I bought a used one. Maybe I need to get a new switch. Thank you for your recommendations, Dmitri |
06-12-2007, 09:51 AM | #2 | ||
yum
Have you tried to change the light relay?
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
07-12-2007, 12:22 PM | #3 | ||
People say that a ground connection became faulty. Can somebody advise where I can find ground connections in my car?
Thank you, Dmitri |
07-12-2007, 12:23 PM | #4 | ||
I didn't change the light relay.
08-12-2007, 02:58 AM | #5 | ||
yum
Try testing first the fuses in question using a multimeter. Sometimes they can get a hairline crack thats not immediatly visible.
Go onto google and check out "car electrical problem diagnostic"
2005 LS Focus LX
