Old 18-04-2008, 07:30 PM   #1
mattp
mattp's Avatar
Default Slotted rotor question (RDA)
Hi all, I just got my 'new' Tickford brake set-up for my AU1, which included brand new RDA slotted rotors (which are huge!). The calipers etc need a clean up, but all looks good. Anyway, my question is, what is this strange bit 'missing' from the rotor, looks like it's been machined out so I assume it's meant to be there, but just curious as to it's purpose... It's in the second photo, and it's only one rotor that has it. My old RDA slotted rotors don't have any bit like this on them. (Sorry it's a little blurry)
Thanks in advance.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2008, 07:33 PM   #2
poolkeeper
Its Resonating!
poolkeeper's Avatar
my ac delco, and dba rotors both have this, interested to know what its for?
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2008, 07:42 PM   #3
mik
mik's Avatar
balance.
Old 18-04-2008, 08:29 PM   #4
mattp
mattp's Avatar
Thanks mik!
Old 18-04-2008, 09:00 PM   #5
The Dok
The Dok's Avatar
I would have thought they'd be wear indicators!
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2008, 10:01 PM   #6
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
I run RDA 330 Rotors on my ED, they are great, no prpblems even though one is totally machined on the outside and one isnt.
Great rotors.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2008, 10:11 PM   #7
Mechan1k
Mechan1k's Avatar
Mine have this as well.
I have no idea why it is done ... not sure if it is a wear indicator ... i wouldn't thing you'd wear through rotors that much.
Old 18-04-2008, 10:34 PM   #8
tufLTD
tufLTD
tufLTD's Avatar
Nothing to do with balance or wear.
Just poor casting, although it doesn't affect the rotor.
Balancing involves removing or adding material but, as you can see, the area missing is "as cast".
Also, if your rotor wore that much, it would shatter long before it reached that area. Maximum wear on a rotor is around 3mm.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2008, 12:12 AM   #9
mattp
mattp's Avatar
What do you mean by 'as cast'? If the outer bit is there how can in be a casting issue? How would an area that had been machined out to balance the rotor look? Just trying to understand. As long as it isn't a defect, as such, I don't mind, though it does look a bit dodgy.
Old 19-04-2008, 12:18 AM   #10
mik
mik's Avatar
looks to me like its been ground off but your probably right
Old 19-04-2008, 12:30 AM   #11
tufLTD
tufLTD
tufLTD's Avatar
If an area has been machined out it will be relatively smooth, like the outer edges of the rotor. The bit missing has a rough cast finish. This is the area that they fit the sand plugs to form the vanes, which haven't been lined up too well.
