Old 16-06-2008, 09:00 PM   #1
ayeyew
Teh Baest
ayeyew's Avatar
Default Polished intake manifold + throttle body..
Up on ebay
http://search.ebay.com.au/_W0QQsassZgurwinder351
claims around 18rwkw with both of them.
Would it be worth the investment?
It was for an EF, but never got fitted.
Will probably end up at around $600 for both of them. So about $30/rwkw
not bad
What does polishing the intake manifold and throttle body actually do? Does it just decrease the resistance to airflow or something?
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2008, 10:38 PM   #2
stiddy
stiddy's Avatar
I dont see 18rwkw from that. Buy it and find out?
I can't see you netting any gains from any throttle body work.(unless force fed)
As for the manifold well.. I doubt it.
The only real way to make power over the standard manifold and throttlebody set up is to go for a 6 individual throttlebody setup. But at $4000+ makes it out of reach for most.
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 05:38 PM   #3
blackwolf3060
blackwolf3060's Avatar
im currently winning the bid for the Intake manifold so ill let you know if i win and how it goes...
Duel Fuel, 3.9 diff gears, s/steel cat, pacemaker extractors, 2 1/2" sports exhaust, K&N pod filter in airbox, 3" stainless pipe from airbox
: NOW BLUEPOWER TUNED!! :
: MY CAR!! :
blackwolf3060 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 07:16 PM   #4
blackwolf3060
Damn i was outbid! should i go up more??? What should i be paying for something like this??? 32mins left!!!!!!!!!!!!!!!
: MY CAR!! :
Old 17-06-2008, 07:26 PM   #5
efgiar
rofl copter
efgiar's Avatar
the TB is worth it, 200 bucks to get that done from someone (thats what ive been quoted, the manifold aint worth it, see what snort have on an upper manifold plenum ;)
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 07:29 PM   #6
blackwolf3060
hmmm yeah u may be right...i might let this one go..sorry to hijack the thred ayeyew!!!! :
: MY CAR!! :
Old 17-06-2008, 07:31 PM   #7
MADED-6
MADED.6
MADED-6's Avatar
hey josh the carby joint shaves the carbys to make them bigger for $120 and grechie did it and felt a difference so might be worth it.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 08:16 PM   #8
Sleeperau
Highway Taxi
Default Tb
SS Inductions stoped making the modded throttle bodies for the AU I6 because there was no power gain.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 08:24 PM   #9
stiddy
stiddy's Avatar
And Ive seen first hand an aftermarket bigger throttle body put onto an EF and dyno run on the same day and there was 1-2rwkw right up high in the rpm range.
A bigger throttle body MIGHT gain something on a heavily worked 6, but not on a basic modded 6.
So it makes sence not to bother with one unless your going for every last rwkw possible.
