05-06-2005, 04:46 PM | #1 | ||
MY21.5 Mustang GT
Im in the process of wiring up driving lights on the EL XR6.
I cannot for the life of me find a hole in the firewall to feed a wire through for the switch. Does anyone know where I might find one, or where I can feed a wire through the firewall? Cheers
05-06-2005, 05:51 PM | #2 | ||
Low and Loud
if its auto, you can use the Clutch Cable hole...
Ive ran alot of my wires thru the firewall where the main loom enters the cabin ;)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
05-06-2005, 06:09 PM | #3 | ||
MY21.5 Mustang GT
What if it's a manual? :P
Thanks anyway lol
05-06-2005, 06:35 PM | #4 | ||
Not your average EF Wagon
Use the hole where majority of the wires feed through already. Its located just under your brake booster. It may be a tight squeeze but, this is the only hole I recommend to use. The wires feed through a rubber sleeve fitted on the firewall.
Power by HeadTech Performance Williamstown The recently SOLD 95 EF Wagon 5spd NA SLEEPER The Daily cruisers now *95 R33 Skyline GTS-T RB25DET *93 Lexus GS300 2JZ-GTE Car enthusiasts visit Unique Cars and Parts
06-06-2005, 06:37 PM | #5 | ||
MY21.5 Mustang GT
OK I'll give it a go tomorrow evening....only one wire needs to fit through.
I've just fitted the lights to the front....had to make up custom brackets as there is NOWHERE to mount the damn things...luckily there was a flat part of metal above and behind the light to fix the bracket to.
06-06-2005, 07:49 PM | #6 | ||
Drill a nice fat hole through the steering column plate ;)
I did that (well, I did more than just drill *one* hole) when putting a cable thru the firewall -Dave- |
07-06-2005, 08:36 PM | #7 | ||
MY21.5 Mustang GT
DONE!!!!
I ended up using the accelerator cable hole, was easy to access and had plenty room.... Im very pleased with the results!! I still need to tidy up the wires a bit. And the light shines under the car at the front, almost looks like white neons or something LOL, I'll need to try and block that off a bit. I might try hacking up the vent cover that I removed, to block up the hole on the outside of each light, make it look a bit more snug....but I'm quite pleased with the result!
05-07-2005, 06:40 PM | #8 | ||
I WANT SOME!
where did u get em from? |
05-07-2005, 06:47 PM | #9 | ||
MY21.5 Mustang GT
lol...
I got htese ones from Repco, they had a good sale on recently, 20% off all driving lights. They are Narva ones from memory, were about $150.
