Old 14-01-2009, 10:46 AM   #1
blue_focus
Default Fly wheel
Hey ever1 not sure if this has been posted before bit I was thinkin about gettin a lightened fly wheel for my focus. Just want to no if it will make a differenc or not. My main goal is to run a be 1/4 mile. Thanks.
blue_focus is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 10:58 AM   #2
819_FLY
819_FLY's Avatar
Lightened Flywheel should make the engine rev up quicker due to the lower amount of weight that it has to spin around, you should get a new clutch that suits the application desired. Given it will rev quicker should in affect mean that acceleration would be improved marginally. If you haven't prob run your car down the 1/4 mile and see how good you can get with its current combination and then you could appreciate the mods you do to your car to make it faster that little bit more.
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 11:20 AM   #3
BlackLS
yum
There are some disadvantages to lighter flywheel. Mostly loss of torque low down.
2005 LS Focus LX
250,000kms.
Old 14-01-2009, 01:46 PM   #4
Mullett
Badly Focused
Mullett's Avatar
For drag racing it will make very little difference on a low-powered car like the Focus, maybe 0.2 of a second, learning to drive it will yeild more :P For track racing, it's definitly worth having, any rotating mass you can eliminate is great. It's a common misconception that you lose torque, it is easier to stall the car, but this is due to less stored energy, the power and torque output of the engine does not change.
The flywheel is simply a device for storing energy, but it takes energy to spin it, so apply the weight to your application. A tune will give you far more, and cost far less...
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 04:47 PM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
I've always assumed a lightened flywheel means quicker to get to higher rpms when you push throttle, but will lose momentum quicker when you take foot off the throttle (ie not as much stored energy)
A very clumsy way to describe it....but basically right??
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 04:53 PM   #6
More revs
I found it improved control in the rally car. And a low mass clutch which is a good thing to do at the same time made gear shifts much faster...
I say go for it if you have the budget.
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 04:53 PM   #7
BlackLS
yum
But less mass in the lower RPMs means there is more force acting against the rotation of the engine in the compression stroke.
2005 LS Focus LX
250,000kms.
Old 14-01-2009, 05:00 PM   #8
BlackLS
yum
I'd still go for it, if your in the high end RPMs a lot. Seeing as the Focus idles on the freeway at 3100 RPMs then you shouldn't find it a big inconvenience.
2005 LS Focus LX
250,000kms.
Old 14-01-2009, 07:24 PM   #9
More revs
Its also a good time to drop in a close ratio dog set in the box. Makes for dead easy lightning fast gear changes,,,
But on apprentice wages maybe not..
Old 15-01-2009, 12:07 AM   #10
Mullett
Badly Focused
Mullett's Avatar
Pretty much right though mate, it takes torque to spin up the flywheel, and it releases torque when it's spinning down. The lighter the better for a racecar, for a street car, you want a compromise, something that still allows an easy takeoff, but is light enough to allow a good spin up.
I stand by my point about the tune, a good flywheel will cost you $500++++ plus fitting, where a tune will be $3-400, release *real* power, and improve the throttle response (the real advantage of a light flywheel) immeasurably.
-RM
P.S. *if i missslept...blame the scotch*
P.P.S *or if imy advice is complete bollocks*
Old 15-01-2009, 12:33 AM   #11
BlackLS
yum
-RM
Get both the tune and f/w
2005 LS Focus LX
250,000kms.
Old 15-01-2009, 09:02 AM   #12
melbzetec
melbzetec's Avatar
One of the better kits going around. matched clutch and flywheel. Exedy. (US Dollars)
https://ssl.perfora.net/www.massives...dex.shopscript
Old 15-01-2009, 10:04 AM   #13
819_FLY
819_FLY's Avatar
Get this!!!! :
Check out 819FLY!!
Old 16-01-2009, 01:13 AM   #14
Mullett
Badly Focused
Mullett's Avatar
If you have one million horsepowers :P
On the other hand, I can get trade price on Excedy clutch kits, if you're really keen on one I can try and source a price for you.
-RM.
Old 16-01-2009, 05:50 AM   #15
melbzetec
melbzetec's Avatar
mmmm link didn't go to the right place before.
Anyway, i was trying to link to this at Massive Speed Systems
Exedy Hyper Single System
Order no.: MCHW'Exedy Focus Clutch
Our price: $ 1,157.19
Hands down the finest clutch system available for the Focus.
Includes a high strength Chome Moly flywheel, 6 Puck Sprung Disc, lightweight Aluminum Pressure Plate, and install tool. Its the only truely different clutch/flywheel/pressure plate setup out there. It uses a forged aluminum pressure plate cover thats acctually stiffer than the stamped steel cover every other factory and performance clutch is based on. That allows a higher lever ratio, the pedal effort is still superb, and there is no clamp load deflection. Not to mention lighter weight.
Since the pressure plate is so much lighter, Exedy was able to incorporate a 1 piece Chrome Moly flywheel that is stronger than either a stock or aftermarket aluminum piece.
The disc features a sprung hub so it can still retain a fairly smooth engagement. This also reduces harmful the shock to the drivetrain. That said, this setup has a very different feel than anything else we have ever tried, and will take a little "getting used to". We have found that this is fairly easy to do.
This setup can handle more power than any other currently available Focus clutch. Numbers show approximately 400% more holding capacity than stock.
Old 16-01-2009, 10:31 AM   #16
More revs
Reminds me of a notice on the wall in one of the rally davelopment teams.
To go fast costs money.
How fast do you want to spend?
How true....
Old 16-01-2009, 02:42 PM   #17
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Quote: "To go fast costs money. How fast do you want to spend?"
Yeah, I've had mates who've won their respective Classes in Production Cars and that's pretty much how it is in the industry. Oh, I noticed the 2 Britek Fiesta's are still for sale/lease.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2009, 01:02 PM   #18
blue_focus
Thanks for the help. It really doesnt sound like it worth spending the extra money for the little extra performance. Will have to keep searching for more budget performance mods.
Old 19-01-2009, 01:12 PM   #19
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
Yep too true... I've spent more than 12k on mods for my focus and most of that was just the brakes, the rest is all cosmetic.
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2009, 11:19 PM   #20
Mullett
Badly Focused
Mullett's Avatar
Intake
(cat back) Exhaust
Tune
Then a turbo if you want to go any faster
-RM.
Talking of which, I might get a round of hard-pipe intake pipes made up, I'll post a thread about it and get an idea of how many I can get rid of when i get back home (about a month away :( )
All the ones from online seem crappy/overpriced, I doubt it'd cost more than $50-100 for the pipe and silicon connectors.
Old 20-01-2009, 10:05 AM   #21
More revs
Intake
(cat back) Exhaust
Tune
-RM.
I'm in....
Old 20-01-2009, 12:36 PM   #22
BlackLS
yum
+1 here
2005 LS Focus LX
250,000kms.
Old 20-01-2009, 09:43 PM   #23
Mullett
Badly Focused
Mullett's Avatar
Ok, I'll measure up when I get back to Perth. Most likely run it straight down from the TB, then across infront of the passenger wheel, behind the foglight. Anyone have any better ideas?
-RM.
Old 20-01-2009, 09:51 PM   #24
More revs
I was just gonna shove a pod in the hole left by the std airbox. So ur plans are much better so long as it's easy to access the filter....
I ran around a while ago with no filter connected - cool and wet with no dust. Anyhow it pulled like 16 year old so there;s a noticeable gain lurking in the inlet.
Old 21-01-2009, 12:43 AM   #25
BlackLS
yum
Bring it into the front airdam.
2005 LS Focus LX
250,000kms.
Old 21-01-2009, 08:38 AM   #26
More revs
bingo
Old 21-01-2009, 09:42 AM   #27
BlackLS
yum
Might need to make it adjustable so you can twist it around when it's raining hard.
2005 LS Focus LX
250,000kms.
Old 21-01-2009, 04:17 PM   #28
Velociraptor82
Eat my Brake Dust
Hmmm.... kind of reminds me of this thread I found:
[font='Verdana','sans-serif']http://www.audiforums.com/forum/showthread.php?t=80267
funniest thing I ever heard and I thought I knew little about engines... [/font]
Old 21-01-2009, 04:24 PM   #29
Mullett
Badly Focused
Mullett's Avatar
HOLY
-RM.
Old 21-01-2009, 09:59 PM   #30
819_FLY
819_FLY's Avatar
reminds me of stories of apprentices that when doing a service draining the oil, start the engine up to blow the oil out faster..... then wonder why the engine has trouble running after that. :
Check out 819FLY!!
