Old 19-08-2005, 03:54 PM   #1
Falcon_Awesome
Default Interior Light/Battery
It all started when the interior light wouldnt turn off. It ran the battery flat. So I took the light out but the battery wont last any longer than 24hr unused.
Old 19-08-2005, 03:57 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
If the interior light wont turn off that would mean a voltage leak somewhere.
Try pull a few non essential fuses out and see what fuse is causing the problem, then work out what that fuses controls.
Trouble shooting sux.
Old 19-08-2005, 03:57 PM   #3
CruizinEB
That rely dosen't sound good, maby a short somewere
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 04:16 PM   #4
Falcon_Awesome
IS it possible that ive done something while replacing the cd player? And would it hurt if I un hook everything and give it a go?
Thanks very much for the help guys
Old 19-08-2005, 04:20 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
pull the ciggy fuse out that will confirm if you have made an error.
Old 19-08-2005, 08:00 PM   #6
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Get a New battery
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 08:10 PM   #7
Falcon_Awesome
Battery is nearly new.
Its the CLK CRT LP fuse that is causing the problems. What should I do next?
Old 19-08-2005, 08:43 PM   #8
LUXO_8
windsor user
stands for clock / courtesy lamp.
check all the courtesy light buttons in the doors to make sure they arent sticking / shorting.
other than that, if you cant find the problem it would be time to see an auto elec
