Old 18-08-2005, 12:41 PM   #1
Heeno
Formally knowen as EBus
Heeno's Avatar
Default Quick Diff Question
hi all,
just a quickie, i want to change the ratio of my diff, to about the same as a ef - el, is this possible to do yourself? or how do you go about getting it done?
cheers all
Car: :evilking: 91 EB Fairmont 3.9L :evilking:
Changes: 5 spd manual
Extractors, 2.5in exhaust
AMG Quake 17's w/ maxxis rubba
Lovelle superlows
Cheap a55 Pod Filter
Bike: CR250R 05 :evil3:
Heeno is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 12:43 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
So you want about 3.45 with ot without LSD
Old 18-08-2005, 12:45 PM   #3
LTDHO
The one and only
LTDHO's Avatar
You can change the whole diff but you will have to change the handbrake setup.
the gears can be swapped but it is best to have it donr by a pro to set it up right.
Tuned by CVE Performance
Old 18-08-2005, 04:52 PM   #4
Heeno
Heeno's Avatar
yep your on the ball dellboy, well i know stuff all about LSD, but the track i hit up has alot of corners, so what would you recommend lsd or not, and no i don't like or want to drift, i go for times.
how much would it cost (guesstimate) to have done what you stated LTDHO?
cheers for your input guys
Lovelle superlows
Old 18-08-2005, 04:56 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
I think around 500-700 to have a 28 spline diff (i think you already have) changed to 3.45 including gears, LSD will just stop one wheel spinning by default, and probably highly recomended
Old 18-08-2005, 06:09 PM   #6
saudia_man
did u say the track you hit up?
what track? in your ea? hahahahahaha
get a spool
saudia_man is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 08:55 PM   #7
sphell
sphell's Avatar
the ratio of your current diff Vs an ef/el will be about the same. What you wanna do is get an ED XR diff like Dellboy has said or get some skyline gears and an lsd center put into your current diff. XR diffs go for about 600ish, to rebuild it with new LSD and skyline gears will be about 900.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 01:14 AM   #8
cominthru
Doof Doof Operator!
cominthru's Avatar
I got a EB gli...think thats got gay slow diff! i was thinkin of upgrading to the 3.45 LSD or without...can ya just change the gears and u need new housing or from hub to hub or ?
EB2 Turbo & Territory SZ Titanium
cominthru is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 09:48 AM   #9
Heeno
Heeno's Avatar
ah cool , cheers fellas, now i just gotta scab around and see how cheap i can get this stuff. would wreckers be a possibility?? or do you generally need to buy this gear new?
once again cheers for the advice
Lovelle superlows
Old 19-08-2005, 10:56 AM   #10
Brent79
When you people say 28spline, are you saying that the axle splines on EB/EF are different??? So if i got gears from a EF sedan and put them in an EB wagon, id have to take the axles from the EF aswell? Do they all fit in?
Brent
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 03:34 PM   #11
EFFalcon
Last warning
EFFalcon's Avatar
get a spool
dare i say it there are plenty of EA's that would kill ur car around a track.
lets not start abusing peoples cars.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 20-08-2005, 12:39 AM   #12
cominthru
Doof Doof Operator!
cominthru's Avatar
Originally Posted by Rollin
Brent the actual crownwheel and pinion gears have nothing to do with the required axles.
all EBII onwards to EL axles are the same, the only difference is between ABS and non ABS.
the centers (all 4 pinion) and diff gears between those models are all the same, and are also the same as VL onwards live axle commonwhores and australian R31 skylines and pintaras, though pintaras only have a 2 pinion center.
So even with my EBII gli like 2.7 diff non ABS...i can fit the EF or EL XR 3.45 gears in there no hastles or ?
Old 20-08-2005, 12:42 AM   #13
Damo
why does your EBII have a 2.7 diff ?
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2005, 12:43 AM   #14
cominthru
Doof Doof Operator!
cominthru's Avatar
dunno isnt that wat is it standard? i forget it's something like that aint it?
Old 20-08-2005, 12:45 AM   #15
Damo
EBII should have a 3.27.. :S
Old 20-08-2005, 12:47 AM   #16
cominthru
Doof Doof Operator!
cominthru's Avatar
hahaha hmmm mayb it does had 3.27...just checkn thru the gregory's manual! so i guess the 3.45 gears are piece of **** to change into mine then!?
