Audi S3
Gday guys,
got a weird thing happening. on these hotter days when ive gone for extended drives, once i park and go do whatever i do, i come back and my car has dumped considerable amounts of oil on the ground? temp guage always reads in the N-O or normal so its not playing up. the oil guage is still in its usual spot in the cluster (dont even know what it measures?) so i dunno? any ideas? cheers. henri
Formerly MR BAXR6t
Have u had a quick look under to see roughly where its from?
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
![]() Join Date: Nov 2007
^^ agreed!- dont sound normal to me henri, i have never encountered this. I know my sump plug must drip a little when its hot cause i have splash back behind it on the sub frame- but not a drop on my driveway.
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC |
XR6T 400kw(well one day!)
Are you talking about engine oil?
This type of problem is common with transmission leaks.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory |
i am talking engine oil, dont know what henri's leak is- tranny fluid is generally red?
Trans fluid can be dark as well ... if it hasn't been serviced in a long time.
When i first picked up my AUII years back .... my first trans service saw the fluid come out like black water literally. On a hot day and really pushing an auto ... it can blow some fluid out through the top breather in the auto ... leaking down the side of it and onto the driveway. I'd need to look under the vehicle to see i it though. Another place for engine oil is the cam chain tensioner ... on the driver's side of the engine ... a leak is hidden from there ... behind the power ster reservoir bracket ... and the exhaust manifold heat shield can hide it as well. It won;t leak when cold ... just after hot running and oil pressure is up. It looks like a leak from the front driver's side corner of the sump initially ... but it comes from higher up. Oil consumption is minimal if it all as it is not a constant leak.
Audi S3
the engine sump is covered in grease and crap, so could be coming from there.
i have noticed the occasional drip from the sump on the transmission as well. BUT, my tranny was serviced about 30 000 kays ago. the oil is coming from the front of the car, which leads me to believe it is engine oil. im getting a service in the next couple of weeks and ill get the transmission done again too. ill have a look under my car before i go out in a minute. its weird as. ill let yas know.
Audi S3
ok, the oil sump on the motor is looking suprisingly clean. all the rain must have cleaned it.
but there is a stack of oil/grease on the 'box, on all the stuff up behind the fluid pan towards the back of the car. so dunno why my car looks like its ****ing oil from the front, or i just didnt realise how far forward the transmission is? you guys reckon a service will fix it?
#9 | |||
When a car is stopped, some of the fluid leaves the converter and back into the pan. As the oil rises it can squeeze out.
give it a degrease underneath, have a check the following day should reveal the offending leakage.
Well ... it could be a number of places on the transmission though ... i had a leak from the passenger side (overdrive cover gasket????) .... the main place though especially from hot driving is gtom the breather on top of the box ... and it then usualy leaks all over the top/back section of the transmission ... and down the extrension housing ... and then spray everything along the undercarriage.
At least the underside of the car won't rust :hihi: I'll try and dig up an excellent post from one of the Territory guys on 4-speed BTRs ... with pics of common leak areas.
Read this ENTIRE thread ... you will have a better understanding of the old 4-speed cluncker.
http://www.fordforums.com.au/showthread.php?t=21444 Say thank you to Jonhydep from the Territory section ... and other associated members in there for the tech details and pics.
#13 | ||
Audi S3
Thanks Simon! awesome!
#14 | ||
G'day guys,
Have a similar problem (AU2, 2001), costing me an arm and a leg, because I've entrusted a local mechanic. Engine oil leak from front of engine, soaking serpentine/fan belt. This leads to oil all over the front of the engine, and requires degreasing & pressure washing of the engine to find the source of the leak. Mechanic has removed head twice, the first time having the head machined, changed all gaskets, and modified head gasket on head-off number 2 as per a friend of his who works for Ford in Sydney. Lots of silicone to be sure. Timing cover assembly off multiple times Apparently there is a bolt in the timing cover assembly that extends into an oil gallery. Mechanic takes it for a drive, and tells me he can't see any leak. I drive it home, at speeds of between 50 and 100kph, 15-20 minutes, pop the bonnet, and watch a drop of golden oil form on the base of a bolt in the timing cover assembly. The front of the motor is very clean because of multiple degreasings/ pressure washings, so I just wipe that drop off and watch another form (even with engine off). Looks like the drops are originating from between the timing cover assembly/case, and the engine block, where a washer is located. Is this making any sense? I'm just a little cheesed off with the mechanic, because before he took the head off the second time, I showed him that the oil leak seemed to be from this point. The underside of a lip (horizontal) along the front of the engine block isn't accumulating oil, so I could confidently tell him that the oil wasn't coursing along this lip to said bolt; nor was it being deposited on the bolt by being flung up from below - otherwise it would be on the underside of this lip. HELP! Is there anyone who knows of a common oil leak from this bolt? If need be, I'll post pics of the offending bolt (but not the mechanic). Thanks in advance. Derek. |
#15 | ||
Problem resolved, FYI. It was a bolt that runs thru the timing case cover into the block (terminating for some unknown reason in an oil gallery). Only after mechanic replaced this bolt with one with a larger (OD) shank (and lots of goop) did the oil leak get fixed.
#16 | |||
Cheers |
#17 | |||
Flairs - Truckers Delight
