24-10-2009, 04:46 PM | #1 | ||
Hey Hey,
I put on a serpentine belt cover the other day and since i replaced the bolt with the stud i cant stop it from leaking. Ive replaced the o ring and it still leaked. Replaced the o ring again and sanded both surfaces till they were dead smooth, I even checked it with feeler gauges and its perfect. Why does it still leak ? It gets wet where the top housing meets the lower housing then drips onto the ac pump. Suggestions ?
AU XLS. |
24-10-2009, 05:19 PM | #2 | ||
use some permatex form a gasket in between the two surfaces that are leaking.
24-10-2009, 06:04 PM | #3 | ||
also, how much tension have you got on the thermostat housing now that you are using the stud?
24-10-2009, 06:04 PM | #4 | ||
I didn't want to use goo but i did put some on anyway, I'm going to let it cure over night and test it then.
AU XLS. |
24-10-2009, 06:05 PM | #5 | |||
AU XLS. |
28-10-2009, 05:20 PM | #6 | ||
All sorted???
28-10-2009, 05:23 PM | #7 | ||
Flairs - Truckers Delight
gasket goooo is your friend
28-10-2009, 07:53 PM | #8 | |||
AU XLS. |
01-11-2009, 02:30 PM | #9 | |||
AU XLS. |
01-11-2009, 06:11 PM | #10 | ||
Boost Addict
is the housing cracked? (micro crack which expands when hot)
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
01-11-2009, 06:23 PM | #11 | |||
AU XLS. |
02-11-2009, 12:02 AM | #12 | ||
i usually get a bit of sand paper on a piece of glass or whatever i can find thats uniform with some 100 grade and give the face a bit of tickle up just to make sure its a flat surface.
