Old 12-11-2009, 06:25 PM   #1
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Default dash cluster symbol s1
g'day, can someone tell me what the symbol to the left of the odometer in a low s1 is, its a ! With a circle around it and in brackets. Cheers.
Old 12-11-2009, 06:48 PM   #2
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Sounds like handbrake.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2009, 06:48 PM   #3
BIGJB
BIGJB's Avatar
mis read post. DOH.
As said above hand brake.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2009, 06:56 PM   #4
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Originally Posted by 99GHIA
From memory with out looking at the book it's the brake fail warning light.
Please someone correct me if I am wrong.
Thats what i thought, i can't check my book i'm at work. I topped up my brake fluid it was low but the light hasn't gone out thats why i thought it was something else. Gees i can't wait to do my suspension and upgrade to au 2 brakes.
Old 12-11-2009, 07:02 PM   #5
blownv8au
Pro Street Au Ute
blownv8au's Avatar
mis read post. DOH.
Nope you were right the first time thats the first thing i tried it had a different symbol as i recall. But will check when i leave work in case i'm wrong. Cheers guys
Old 12-11-2009, 07:07 PM   #6
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
sounds like handbrake Switch playing up try and unplug it pull the hand brake boot off and unplug the conecter down there and see if it gose out if so then u need to reco the switch like i did or replace it
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2009, 10:31 PM   #7
Peuty
Afterburner + skids =
Peuty's Avatar
Handbrake is a P in brackets isn't it?
Oo\===/oO
Peuty is online now   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 02:28 AM   #8
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Yep.
The message you have entered is too short. Please lengthen your message to at least 5 characters.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 07:55 AM   #9
JC
JC's Avatar
The ! in a circle is the brake symbol.
Ford Performance Club ACT
Old 13-11-2009, 02:21 PM   #10
blownv8au
Pro Street Au Ute
blownv8au's Avatar
it certainly is mate, as jc has said its the brake fail symbol but it has not gone off since topping up brake fluid but is still braking the same may have air pocket around sensor. i will bleed the entire system and change fluid type when i upgrade. thanks everyone for your help. cheers preston.
Old 14-11-2009, 01:34 PM   #11
rosebush
rosebush's Avatar
The park brake indicator light is a circle with the letter "P" around it in brackets. This is also a Brake system malfunction warning light....HOWEVER
this year I had major brake booster problems and rear heating of fluid and the only light that appeared to come on and that warned me was the one your talking about....It was the same the "P" one but with a "!" in the circle...I could only assume it too is a brake system problem. The light has never come on again since I had the job repaired....Hope this helps as I cant find anywhere in the car book that same symbol.
rosebush is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2009, 03:06 PM   #12
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
I had that (!) light light up on my dash last week. Went to stop at some traffic lights and the pedal went to the floor. Pumped it up and it stopped ok. Kept coming on and off. Checked the fluid and it was ok, turned out to be a slightly sticking rleft rear calliper causing tremendous heat and boiling the brake fluid, hence no stop.
So yeah, definately the brake system malfunction light. Get it checked ASAP. If its still stopping ok, it may just be a dodgy connection somewhere or as said an airbubble in the system or brake booster on its way out, who knows. But get it checked out, No brakes is not fun let me tell you. Lucky when mine decided not to work i was only crawling along and was at the front of the que at the lights.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
