09-09-2005, 11:31 PM | #1 | ||
XF 250
Hey guys, i thought this may get abit more attention as i really need help with this, please check following link
http://www.fordforums.com.au/showthread.php?p=312580 |
09-09-2005, 11:36 PM | #2 | ||
sounds like a mixture problem
09-09-2005, 11:52 PM | #3 | ||
I'd check if you've got fuel pressure, you should be able to hear the fuel pump prime when you first turn the ignition on (while switched on petrol). If you dont have a pressure tester, turn the ignition on and allow it to prime, then switch the ignition off and loosen (not too much) one of the fuel lines coming off the fuel rail, if fuel starts spitting out at pressure theres a good chance youve got good fuel pressure.
Proud Owner of 06' TTG |
