Hey guys,
My mate picked up a series 2 au xr6, with sill and door damage for 500 But he has lost his keys to it, Does the car have to be taken to ford to reprogram the new set of keys to the car or can we do it our selfs Any info or guides would be good cheers
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
T Series Club Member No24
Ford do have key codes on file. Either Ford or a good locksmith can program the keys in but as you have none a minimum of 2 need to be programmed in. Obviously a programmer is required
1967 XR Falcon Mountain Blue Worked 250 2v , Kitted C4 , LSD , 10x14 Rear 9x14 front (LOW and FAT) had for 26 years....magnificent! FTe Venom T3TE50 No229 5.6L Manual Don't drive one! Because like so many others , including ME , you will become TOTALLY addicted. 2016 Harley Davidson Softail Heritage customized. Dead set gorgeous! |
Blue Blooded
as above you will need to get 2 keys made, the car is needed also to program so he either needs to get it to the dealer/locksmith or get a locksmith to come out to the car, either way you won't get much change out of $500 once you add in a tow, 2 keys @ $160 each plus labour to program etc. And if he then finds the keys after new ones are made, they won't start it anymore as old keys drop out. HTH
351 clevo
take the handbook and/or the body no. to ford and they will cut and program the key to the car with out that hassle.
unless the locks have not been changed i had to do it with my ef but ford will do keys with out the car
2006 ford territory turbo stock as a rock for now 2004 territory ghia click here for pics work daily ke laser ghia RIP click here for pics Daily EF II fairmont wagon RIP click here for pics XD 351 clevo lowered click here for pics thanks to p.e.a.c.h performance at stafford http://www.peachperformance.com |
Thanks guys will let him no, we just want to start it thats all, its being wrecked out, cheers
