21-09-2005, 12:57 AM | #1 | ||
any one with some good info/tips on best way to convert ea 3 speed auto to 4 speed. just brought a bomb eb for tranny, pulled it out and want to know any useful tips on how to convert the easiest way.........
21-09-2005, 01:36 AM | #2 | ||
Two > One
easiest way would be to swap all of the looms from the EB into the EA. ALL of the looms (assuming both cars are MPFI).
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
21-09-2005, 02:34 AM | #3 | ||
its not a!
You may need to change the diff too, someone else may be able to give more detail, im too tired :P
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
21-09-2005, 09:53 AM | #4 | ||
PM me if you want
Yes change the diff as well, or the 4 speed auto is really no point at all.
Lets not forget the hardest bit is the fact the gearbox is not straight bolt up, I have heard a 5 speed u-shaped gearbox mount will fit and hold the gearbox in place, or just use the standard straight one and get some brackets made like these: Also attached is the wiring diagram if you wish to integrate the 4 speed auto computer and loom into the EA (this is how I did my conversion).
21-09-2005, 10:26 AM | #5 | ||
Former E-Series Member
If you're in Vic I have some cheap 4 speed trans cooler lines. I got ripped $35 at Jollys then found I had some from my EL already in the shed.
21-09-2005, 03:45 PM | #6 | ||
yeh both MPFI. so now whats the easiest way to take the looms out with out to much stuffing around?
21-09-2005, 03:51 PM | #7 | ||
PM me if you want
pull the dash out to swap the looms, and yuo have to swap the engine bay looms as well, is the donor eb smartlock?
21-09-2005, 03:57 PM | #8 | ||
that is a bit of a pain in the *** thuogh. yeh it is smartlock
