Old 19-01-2005, 09:13 PM   #1
InitialD
Low and Loud
InitialD's Avatar
Default Help! Im about ready to blow the thing up!
Well after last week where my alternator died, I couldnt belive anything else could go wrong :
While driving back home tonight, after about 2mins the car starts stuttering like it had Turetts syndrome. every 1/2 sec it would die then pick up then die, then pickup , etc ,etc ,etc
The harder I revved the car, the more it did it. And ofcourse i got every red light and when it idled at the lights it died then picked up straight away.
Its like the TFI is stuffed or like it didnt have enough fuel?
Earlier today I went to start it, it wouldnt start, But it had spark, and the injectors were ticking. I had to fully open the throttle before it would start, and it had alot of black smoke coming out of the exhaust for 1min (running ritch i guess)
Anyone got ideas?
So far Dave (thanatos) and I have come up with....
ECU
TFI (Ive used the TFI from the old EA and it was new)
DIZZY
FUEL PUMP
COIL
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2005, 09:19 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
last time my Xf did that it stalled and blew the muffler appart *BANG*
Old 19-01-2005, 09:21 PM   #3
AUII_Forte
AUII_Forte's Avatar
This sounds very similar to what my EA is doing!!! I haven't been able to drive the car because it's unreg'd, but it's really hard to start, the timing is up to shit no matter what I do and sucks through fuel like you wouldn't believe! I just can't figure it out, about the only thing I haven't changed is the fuel pump and I can't see that being the cause of the problem. I think it must be to do with the wiring or something, but I really have no idea, hence the reason the car is still in the same state. I gave up on it until i really HAVE to sort it out.
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2005, 09:25 PM   #4
InitialD
Low and Loud
InitialD's Avatar
Ohh and the Timing is perfect on it aswell (checked it recently with a timing light)
Old 19-01-2005, 10:06 PM   #5
oneredED
need more boost
oneredED's Avatar
When you say you have spark... how much spark have you got? When my coil went, it had spark when i tested it, according to the mechanic it was just not enough to get the motor to fire into life. My dosh is on the coil ;)
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 12:10 AM   #6
XRated
Shoot.
XRated's Avatar
If you've done so much to it already, why not do the dizzy, coil and fuel pump... If it's none of them, we will have a mod day where we blow it to the high heavens! :dr_Evil:
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 05:25 AM   #7
Mike Gayner
Mike Gayner's Avatar
Yup my money is on the coil. Doesn't take alot of current at all to fire a plug into the block, but remember inside the engine the spark has to jump across about 12mm gap through compressed air and fuel. Surely a coil would cost sweet fudge all from a wrecker.
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 10:39 AM   #8
NZ
NZ's Avatar
I hope you dont have fat hands if you change it.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 10:56 AM   #9
rag top
rag top's Avatar
Have you checked the cat? might be collapsing??
How good are the injectors? Have they been cleaned recently??
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
Old 20-01-2005, 02:03 PM   #10
InitialD
Low and Loud
InitialD's Avatar
How exactly would you check the cat?
The injectors were given to me from another motor. Unknown how good they are. I originally had another set in there and they were shot, but these seemed to be fine.
HAHAHAHHA thanks karl
Now i think about it, When the car wouldnt start earlier yesterday I thought id check for spark, and amazingly the motor fired up to life when i took the plug out to check for spark, There was a very weak spark aswell. Would this cause it to do what it was doing while driving??
Old 20-01-2005, 02:07 PM   #11
Racecraft
they call me Tibbo
Racecraft's Avatar
What about the earth strap to the block?
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 02:08 PM   #12
BJ
Have you tryed the M.A.P sensor The vacum line could be split and will cause the same thing.
BJ is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 02:13 PM   #13
InitialD
Low and Loud
InitialD's Avatar
the earth connections are fine.
The strange thing its allways done even on CFI was it hunts at idle? say 600 then goes 500, 600, 500 ,600 no matter what RPM your at. Since the conversion to MPFI and MPFI idles at a lower RPM then CFI, its seems to have gotten worse. Ive changed ECU's and it doesnt make a difference. Well actually it did for about 10mins then it started it again. Can a coil cause this? Since converting to MPFI ive changed dizzy, plugs, leads, cap, rotor button, fuel pump, etc the only thing left on the car that hasnt been replaced is the coil.....
Old 20-01-2005, 02:22 PM   #14
spope
spope's Avatar
Black smoke coming out of the exhaust is unburnt fuel. If you are overfuelling, maybe it's your map, ozy sensor or fuel pressure reg, or possibly even fuel pump.
However, if you aren't overfuelling, then your engine is not burning all the fuel, which suggests possibly bad timing, or more likely, weak spark. If your plugs are old, change 'em, otherwise probably coil if it is doing it fairly consistently. A new coil should be less than $40, and if you can't get to it, just pull the manifold off. It's not that tricky.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 07:07 PM   #15
oneredED
need more boost
oneredED's Avatar
Oooohhh, many a pointless hour has been spent trying to get paddock bashers to fire, going over everything 100 times, only to realise a faulty earth is to blame...
'94 ED Falcon GLi
Power from: ???
Cost: stuff all :P
Old 20-01-2005, 09:40 PM   #16
Sundeep
Sundeep's Avatar
Dude when you say that it starts when you hold the throttle open, are you pumping it or holding it down? If you are holding it at WOT the ECU cuts off fuel, you'll hear the injectors stop pulsing and the fuel pump will stop as well. If it starts like this, I'd be checking fuel related stuff because it's obviously overfuelling.
Start with the pressure regulator, MAP sensor (unplugged, busted) and have a go at cleaning out the bores and cleaning/replacing the plugs. After that crank it a few times with the throttle wide open (fuel cut off) and try start it.
I coulda sworn I posted this yesterday ;)
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 10:15 PM   #17
InitialD
Low and Loud
InitialD's Avatar
Well after further investigation this afternoon...
I went to drive the car up the driveway and it spluttered the whole way up. My sister (previous owner of it) said that it use to do that occasionally when her boyfriend had it. Then i started thinking... what havent i changed over yet? COIL!!!
after a painfull removal I discovered that it had a BIG nasty crack in it going allmost 180deg around the outside of it. So im guessing that was one of my problems since its got VERY weak spark atm. I thought maybe it was the fuel pump but when it stalls you can hear it prime again. The other thing i noticed in the ford repair manual is that it shows CFI and MPFI having different relays for the fuel pump??! : Was I suppose to change this??
Old 21-01-2005, 05:31 AM   #18
NZ
NZ's Avatar
you mean the ECU relay
Old 22-01-2005, 09:33 AM   #19
spope
spope's Avatar
Yeah, fuel pump relay is the same. Green. ECU for cfi is white, mpfi black.
No, you don't have to change this. The only difference is with the cfi relay it stays on for 30 seconds after you turn the ignition off, to allow the throttle to reset.
Strangely enough, my car won't start if I put the mpfi relay in. But i haven't had any problems using the cfi one.
Old 22-01-2005, 10:14 AM   #20
NZ
NZ's Avatar
You didnt swap the 2 wires behind the relay block spope.
