Old 13-10-2010, 08:51 PM   #1
my671fordv8
my671fordv8's Avatar
Default Au aircon switching off fixed
Just thought i would share this .My Au series 1 aircon used to work and the the light would go out and would blow hot air it was the standard aircon not climate control.Found out cct board was damaged the solder on the on/off switch was cracked so i resoldered them and it is as good as new $8 for the solder was alot cheaper than the $300 ford wanted for a reco cct board
my671fordv8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2010, 08:56 PM   #2
frd906
Thanks for that mate, my buttons are actually doing the same thing, i press normal aircon mode and it keeps switching off, have to use the max aircon button
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2010, 09:25 PM   #3
my671fordv8
thats the fault . what happens is the switch is mounted to the cct board and flexes when you press the button and eventually cracks the solder .Let me know how you go fixing it or if you want any advice.
Old 13-10-2010, 09:27 PM   #4
frd906
you wouldnt to happen to no where the locating bolts are to take the facisa off,
Old 14-10-2010, 09:36 AM   #5
whiskers
gone fishing
whiskers's Avatar
use this thread to get the centre fascia panel off http://www.fordforums.com.au/showthread.php?t=95787
then take off the air con vent and then there are 5 or 6 screws holding the air con control pop of the back of the unit and then there are 2 small screws holing it down.
once the screws are off you can see the circuit board. don't forget to prise the knobs of lol.
I had a similar problem ended up getting another one from the wreckers (ftg) but had to take that to an auto elec to fix.
hope it all goes good for you
Whiskers
Old 14-10-2010, 10:22 AM   #6
frd906
very helpfull thread, cheers
