Old 01-10-2005, 07:53 PM   #1
Felony
Wherever u go there u r
Default Shim problem installing wade cam,
hi, i have a ea fairmont 3.9 and i just put in a wade 1004 112 today and the shims i got were a touch smaller than the ones already there, does this matter? the car seems to be fine after a bit of a drive...
thanks
Felony is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 09:36 PM   #2
Age182
GMHKLA number plates
Age182's Avatar
im guessing its not a problem because of its bigger durations it wouldnt need the bigger shims behind the lifters
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 10:20 PM   #3
EDXR8
EDXR8's Avatar
I was under the impression that you were suppose to add those shims to the ones already in there to compensate for the fact that the cam has been reground (unless you got a new billet one).
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 10:27 PM   #4
Age182
Age182's Avatar
arnt there fitting instructions :S if not call were you got them from
Previously owned:
14.620@93.3mph
2000 Honda S2000
Old 02-10-2005, 12:18 AM   #5
Felony
um im not after fitting instructions, im asking if using shim and then a slighty smaller shim per lifter will do any damage.....
Old 02-10-2005, 12:34 AM   #6
EDXR8
EDXR8's Avatar
If you use too many shims then the valve won't close fully and the car will run like crap, to little and you will get the ticking sound. Wade 1004's regrinds are suppose to use the 2 shims, that should get you pretty close to the required preloads specs.
Old 02-10-2005, 08:05 PM   #7
Felony
i have 2 shims installed per lifter, my question is does it matter if one set of shims is slightly smaller than the other?
the car goes fine, minimal ticking noise as all ea's do a lil, lol
cheers
Old 02-10-2005, 08:12 PM   #8
EDXR8
EDXR8's Avatar
cheers
No the different sizes shouldn't matter, as long as it doesn't tick too much or run like crap you should be fine.
