11-05-2011, 09:10 PM | #61 | ||
yeah i agree, pumping the break lights is your best bet, but even then, brace for impact.
12-05-2011, 10:23 AM | #62 | ||
FgNewbie
The median strip is wide, but has a hard concrete edge. Thinking about it now, I probably would have done some damage to the underside trying to mount it in a hurry. I have the 2-door version of the WS Fiesta, and with only 16 inch wheels and sideskirts, it sits lower on the road than the majority of other cars. By the way, can I thank everyone who has offered answers to my dumb question? I have learned a lot! I never dreamed the thread would attract so many replies. |
12-05-2011, 10:35 AM | #63 | |||
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
12-05-2011, 10:48 AM | #64 | |||
Ich bin ein auslander
Growing old is compulsory, growing up is optional! |
12-05-2011, 12:43 PM | #65 | |||
The one and only
It's true, I'd rather the car be at a panel beater or wrecking yard than me in hospital or morgue!
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
12-05-2011, 01:07 PM | #66 | |||
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
12-05-2011, 02:12 PM | #67 | |||||||
As long as no one was hurt and your car was in road worthy condition prior to the incident you can sleep well in the knowledge you did every thing you can to both prevent and accident and also reduce the risk of injury to others when this happens
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
12-05-2011, 02:15 PM | #68 | ||||
Australia
12-05-2011, 02:33 PM | #69 | ||||
Australia
12-05-2011, 02:38 PM | #70 | |||
As was said, the OP had two cars ahead and hence there was little if any chance of ending up mid intersection and getting T Boned. Even if you are the first car at the lights, giving yourself 6 feet from the line will still see you activate the sensors for the lights to change and even then, you have room to move forwards without ending up in the middle of the intersection. I'd go forward and then brake (edit: but not full pressure, thus allowing movement but not entirely leaving the car to the will of the vehicle that hit me). The only issue with releasing brakes (edit: completely) though is that you can have double whiplash from getting hit from behind and then hitting something in front. You have to make a conscious decision to keep your head on the headrest to avoid that. I'm curious though, does the ABS then unlock the brakes when a car is being pushed and your foot is planted hard on the brake peddle? Or do you get pushed with locked brakes?!
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue Last edited by kypez; 12-05-2011 at 03:05 PM. |
12-05-2011, 02:59 PM | #71 | ||
Australia
I'll opt out rather than go around in circles.
12-05-2011, 03:01 PM | #72 | |||
The problem with your brick wall example is that you are taking that the entire human body is secured in a car which is not the case (head, arms and legs). The crumpling of the front of the car is "movement forwards" which then results in your body moving forwards. Depending on the momentum and kinetic energy of the object that hits you, you can be accelerated VERY quickly and end up experiencing the same retardation as hitting the wall moving. Just because you're sandwiched doesnt mean you do not accelerate (or move) and prevent injury. So if the wall wasnt there or there was a "softer wall" (ie, another car infront of you) and you were allowing the car to move a little, you would thus experience less impact on yourself thus reducing your injury as opposed to sitting there with the brakes on. Hope that makes sense...
12-05-2011, 03:03 PM | #73 | |||
12-05-2011, 07:49 PM | #74 | ||||||
In the end the idea is to stop the passenger cell from accelerating, that is what causes the injuries, if it stays intact and doesnt accelerate at too great a rate, its very hard to get injured. Focus on what happens to the passenger cell rather than getting yourself confused with where the energy of the collision may or may not go. The more we restrict the passenger cell from changing its motion or changing its motion at a slower rate, the better off the occupanst will be, which is also the function of the crumple zones of both the rear of the car and the front of the other car, to increase the time that it takes to change the motion of the cars. If you allow the vehicle being hit to be unbraked, it will accelerate forwards at a much higher rate, that's what causes injuries...whiplash, concussions, backs etc. Its also the reason why you are not going to get injured if you are the driver of a truck that gets rammed from behind by a ford focus, there is just too much mass in the truck for it to accelerate appreciably and neither do the occupants. Newtons law's and indeed the law of conservation of momentum are not negotiable here, the bigger the mass always enjoys a smaller speed change in a collision. You can make a small mass behave like a heavy mass in collisons if it is connected to heavier masses, ie having the wheels "connected" to the earth or prevented from moving by objects in front of it. Last edited by sudszy; 12-05-2011 at 08:02 PM. |
12-05-2011, 08:14 PM | #75 | |||
The people in the heavier vehicle, or the vehicle "connected" to the ground dont suffer as high a speed change and hence their collision is more survivable. |
13-05-2011, 01:54 AM | #76 | |||
In order to discuss this logically we first have to make some assumptions based on averages. The first of these is that at point of imact in the vast majority of crashes, the impact speed is much less that the posted speed limit. Second, by far the least amount of fatalities and serious injuries occur in rear end collisions. Third, the vast majority of intersection crashes involved passenger vehicles of similar mass, not truck/bus v car. Now that we have that understood, challenge those statements if you wish but you will find the evidence is there to support it. Now let's look at crash dynamics. Firstly the majority of serious injuries or fatalities occur in the front seats plus these positions have the vastly greater occupancy rates. In the front seat on the average passenger car you have approximatey 60% of the vehicle behind the front seats, 40% to the front (remember your body extends all the way to the firewall). This means that in the rear impact you have about 10% more crumple zone to absorb impact before force is applied to the occupant. You also have the greatest portion of the passenger cell behind you which is structurally the strongest part of the modern car, they are designed that way. End result is the occupant is at an advantage in the rear end collision in terms of crash survivability and the stats support this. At normal road speed, rear end collisions in appropriately spaced vehicles at a stop, having the foot brake applied at the intersection both reduces the likelihood of rear collision because of illuminated brake lights and decreases the risk of impacted car being pushed into the car ahead of it. For the next bit you have to understand injury patterns are indirectly related to the extent of the vehicle damage, more vehicle damage does not mean more injury, often it means less injury. The only factor that directly causes injury to the occupant is the amount of force and the number of forces applied to the occupant. By releasing your brake prior to the crash and allowing your car to move without resistance you will save some panel damage at the rear of the car. Instead of that energy imparted on your car bending panels it will move the car. The problem with this is without that energy being absorbed, for example by the friction of the brakes and tyres you will simply travel at speed at the next obstacle without energy dissipation. The result will be that you hit the next obstacle (the car in front of you) with the remainder of the sum total of all the energy imparted on your car. The disadvantage from an injury point of view is now you have not reduced the sum total of all the energy of the crash, you have just changed it from a single vector in the rear collision to a double vector of a rear crash followed by a frontal crash. So really all you have done is borrowed some energy from the rear crash which is less likely to cause injury and passed it to a frontal crash which is more likely to cause injury. One very important factor in crash injury patterns that no one has mentioned so far is the surface area that forces are applied to the body. In a frontal crash the force is applied to the body over the surface area of the seat belt only, maybe the air bag as well if you contact it. Also in the frontal crash the head and neck are unrestrained in the forward motion (no Hans devices in passenger cars), which applies significant force to the neck. In a rear collision the force is applied to the body over the entire surface area of the seat which is much larger than the seat belt (not to mention padded too) and proportionally less likely to cause injury. Also in the rear collision as the force is applied from rear to front the padded head rest contacts the head which not only absorbs impact but helps to support the head and neck, reducing forces on the neck and maintaining spinal alignment. If you were to see the impact coming and brace your back against the seat and your head against the head rest, there would he even less uncontrolled movement of the body and less chance of injury. The moment you allow uncontrolled forward movement of your car, the more changes in direction of the forces occur and the more injuries that become likely. Now this is a car enthusiast forum an we love our cars so let's look at it from the point if view of our pride and joy. If an equal mass car hits our rear at for example 60 km/h and you have your brake applied, you will have extensive damage and the car will probably be a write off. If you are involved in the same crash but no brakes applied you will be pushed forward which will reduce the damage to the rear but unfortunately the remaining energy will be applied to the car in front if you. This will just result in damage to both ends of your car and it will still be a write off. Basically in the act of releasing the brake before impact the only thing that you achieve is increasing your chances of injury as well as increasing the chances of injury to the person in front of you, but either way your car still dies. Sorry but I fail to see the logic in that.
Growing old is compulsory, growing up is optional! Last edited by geckoGT; 13-05-2011 at 02:02 AM. |
13-05-2011, 02:13 AM | #77 | ||
I totalled my XR6
Just waiting for a moderator to close this thread.
I think the OP did all he really could.
13-05-2011, 02:25 AM | #78 | |||
I just had to comment on this stupid idea of releasing the brakes. By the way, I asked my other half (who spent many years in insurance) if you can be liable for the car in front in a nose to tail. Her answer was that if you are stopped too close or do not have your brakes applied, or any other illegal act that contributes to that cars involvement you can be held responsible for that car.
13-05-2011, 02:40 AM | #79 | ||
I totalled my XR6
Yeah, I would have thought the insurance company wouldn't cover you if your brakes weren't engaged.
13-05-2011, 02:46 AM | #80 | ||
I totalled my XR6
I'd like to add that cars are just material objects.
People, however can't be replaced. If it was a choice between wrecking my beloved HR or causing a long-term disability to someone (let alone fatality), I'd immediately choose for my car to be crushed. Sorry for being so PC btw.
13-05-2011, 08:41 AM | #81 | ||||
The one and only
If they did, I'd be interested to know why. Quote:
13-05-2011, 01:18 PM | #82 | |||
Just one extra question though. having this situation with room to move infront, why would you want to just be an immovable object? Wouldn't you allow for most transfer of energy be to the body and then allow for "forward give" to let some of it dissipate as forward motion thus reducing even more the forces on you? Edit: by Give I mean still applying the brakes but at 80% braking rather than full push.
13-05-2011, 02:07 PM | #83 | |||
Personally I think you would be better off planting the brake with max pressure thus using both legs to push your body against the seat and reducing your body movement on impact. The most important thing is to push your head hard against the head rest and keep that pressure until the car has settled after impact, your highest risk in this type of crash really is your head and neck. Trying to think of modulating brake pressure may cause you to forget to do this. In such a crash, tyre slip after impact would provide effective dissipation of energy through friction, releasing a bit of brake pressure is unlikely to enhance this to any appreciable amount. I guess another method that is legal is to apply the hand brake and brace both feet against the firewall. This would provide some resistance to forward movement but only half as only 2 wheels are braked so you are still going to hit the car in front with twice the energy you would compared to having the foot brake applied. Much more than that actually as the park brake is no where near as effective as the foot brake in any car (particularly B series falcons). Personally I would plant the foot brake and brace. This all reminds me of a crash I attended where a small suzuki hatch was rear ended at speed by a B Double, the driver in the hatch was stationary and on the brakes at the time as shown by the skid marks at the point of impact. She was knocked clean across a 6 lane intersection and walked away without a scratch, the car was obviously a write off. Moral of the story is that rear collisions are very survivable.
Growing old is compulsory, growing up is optional! Last edited by geckoGT; 13-05-2011 at 02:21 PM. |
13-05-2011, 02:16 PM | #84 | |||
They would still cover you but as you would be at least partially at fault (they can award joint responsibility) you would have an excess to pay and loss of no claim bonus.
13-05-2011, 06:58 PM | #85 | ||
3 times cars I own have been rear ended, never has the person driving at the time been questioned as to whether they had the brakes applied at time of impact.
13-05-2011, 07:03 PM | #86 | |||
I'm getting the impression based on your eariler posts that you just want to disagree with peoplr go sick man I dont really care
13-05-2011, 07:09 PM | #87 | |||
Basically in normal driving the brake is only applied firmly enough to stop the car creeping against the auto, and as far as I know that is all that is required on any driving test The person that runs into you certainly cant cry foul if they weren't applied, it would reduce the severity of their accident anyway. |
14-05-2011, 07:08 AM | #88 | |||
Australia
I'm not sure which bit you didn't like. That I care less about vehicle damage and expense than injury or my willingness to use a (loud) horn which we both agree will be better heard by those blocking an escape. kypez's reply to my question was more convoluted than I could respond to so I opted out. Conversely, I could have happily replied endlessly until I managed to convey my actual point. Speaking of which, some of my own beliefs have been very eloquently expressed within geckoGT's own posts 76 & 83. Kudos to geckoGT. Occassionally I'm reminded to avoid poor delivery, anything else is optional. Enjoy |
14-05-2011, 09:23 AM | #89 | |||
The one and only
