Old 19-05-2011, 11:44 AM   #1
Mickxr8
Mickxr8's Avatar
Default Mobile disc brake machining
Your thoughts and or experiences with this ?.
Had a guy come around yesterday to do the front discs on a mates el, was a bit dubious about getting em done whils`t still on the car but after seeing it done (And taking video with his permission ) was impressed. We took the wheels and calipers off so the total cost ? $65
Made a quick y-tube vid of it
http://www.youtube.com/watch?v=0E2-gnNaYnQ
(When I said quick,oops, it goes for 5 mins)
"You can't fight stupid people - there's just too many of them.The internet: Access to all the world's idiots
Mickxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 12:08 PM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default Re: Mobile disc brake machining
Never seen that done before.
Liked his safety boots ;)
Old 19-05-2011, 12:19 PM   #3
superpursuit83
KITTY Crew Member
superpursuit83's Avatar
lots of little mechanical workshops bolt the machine to the discs on the car and do there own disc skimming. Not a new thing at all.
FOR SALE
BAII Super Pursuit 0083
Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block
Awesome exhaust by THE EXHAUST CENTRE MIDLAND
Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments
Now with full DOT approval and Permitted for road use
superpursuit83 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 12:30 PM   #4
xisled
Anyone know if these guys can do BA Gt standard brakes. I have been told by people that slotted brakes can not be machined.
xisled is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 01:51 PM   #5
lockieoc
Yes they can be done,
Slowest feed rate with the finest cut.
However i would take them off the car and take them into a reputable shop.
lockieoc is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 01:58 PM   #6
mac_man_luke
mac_man_luke's Avatar
Biggest thing to watch with brakes such as those on BA GT is that generally once worn they are below the minimum thickness already or close enough that machining would make them undersize
2015 Toyota Landcruiser 79 V8 SC
mac_man_luke is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 04:49 PM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
IMO fit NEW rotors...
Since asbestos has been taken out of pads as fiction material ..
Both the pads and rotors need changing more often...
Daily driver GTE FG..
Old 19-05-2011, 06:48 PM   #8
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Nothing wrong with machining discs on car/4WD etc etc.
As for any undersizing worry. The blokes that do any sort of machining, check them before going ahead. That includes mobile brake machinists
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 19-05-2011, 07:24 PM   #9
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
I have had the Mobile Machine on both of my cars and have not had a problem with them.
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 09:22 PM   #10
Airmon
King of the Fairy's.
Airmon's Avatar
Yep and even the big ones will more then likely still own an On-car machiner. Its good for cars where its not so simple to take the disks off, e.g. its part of the hub, then an on-car becomes more time efficient.
www.bseries.com.au/airmon
They say less talk more action,
I say more torque less traction!
Airmon is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 10:54 PM   #11
FgNewbie
Australia
FgNewbie's Avatar
I'm guessing badly I saw it done on a car 15 or 20 years ago.
How long have they been around?
FgNewbie is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 11:06 PM   #12
93EB_SXR6
I totalled my XR6
"I wasn't looking at your bum mate!" hahahahaha
93EB_SXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2011, 11:39 PM   #13
BAGT514
BAGT514's Avatar
With brake set up like the XB 9" on car machining was the only option. It has been around for ages
Official member of the OCMD Club
"Semi - Silhouette" 2003 BAGT #514
2007 GT500 factory supercharged motor built!
Sensation Blue 2011 FG GT-P # 101
KPM Streetfighter Monster
5.2lt MMR short motor / Stage 3 MMR heads / Boss 302 Exhaust cams
FR20 Simmons / Tein Coilovers / Eaton Tru Track / Very scared 305/25/20" Nitto Invo's
ZF fitted with a NIZPRO Stage 2 input shaft & Excedy Clutches
http://www.fordforums.com.au/showthread.php?t=11408502
BAGT514 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2011, 07:30 AM   #14
Tanksenda
Tanksenda's Avatar
On the car machining has been around since the 70s. It's actually better to machine them on the car as it takes into account any hub run out. As long as the wheel bearings have no play and they are in good condition there are never any issues. And yes you can machine slotted brakes.
I live with fear every day....sometimes she lets me go to the pub!
Tanksenda is offline   Reply With Quote Multi-Quote with this Post
