26-10-2005, 06:42 PM | #1 | ||
Hi,
I have just bought a second hand set of 17" ANZ Mayhem wheels. They were off an ED Falcon. It seems they wont fit my EF Fairmont. The stud pattern is the same, also the bearing housing seems it will fit. I measured the stud holes and they are slightly smaller than the standard EF rims. That seems to be the problem :( I thought mags were standard across the E-Series? Only thing I can think of is drill the stud holes bigger in the mags..... Any help appreciated. Dan. |
26-10-2005, 06:57 PM | #2 | ||
they call me Tibbo
unless it was running hub adapters to correct the offest issue they should fit if they were off an ED.. The stud spacing and size is all the same
26-10-2005, 06:58 PM | #3 | ||
they call me Tibbo
ok i have rethought this for a sec
do the nuts not fit on, is that the issue you have? You might need barrell nuts.. I have to use barrel nuts on my AU but my wheels are ex-Japanese and the holes are not large enough for a nut and a convention spanner
26-10-2005, 07:04 PM | #4 | ||
The wheels wont go on far enough for the nuts to fit on.
It does look like the stud holes in the wheels are just a bit to small (its very close!) The wheels wree off this car (ED?): http://cgi.ebay.com.au/ws/eBayISAPI....ayphotohosting |
26-10-2005, 07:10 PM | #5 | ||
Custom user title
are u sure there not hiting the stub axel.. u may need hub spaces.. D0 they fit on the back
26-10-2005, 07:12 PM | #6 | ||
Kaddis Customs
i have 18' mayhems on my EF i think 17/18" would be the same...mine fit easy!
FG XR6 E-Gas Ute in Ego |
26-10-2005, 07:22 PM | #7 | |||
The stub width is around 70mm The stub space in the wheels are about 71mm (they are the same width as the standard rims that are on it.) It seems to be the studs bolts that wont fit through the rim. I would have thought that all the E-Series had the same stud bolt/axel size. Interestngly in the E-Series rims database it lists ANZ Mayhems.... |
26-10-2005, 07:24 PM | #8 | ||
PM me if you want
IS it only a problem at the front, you often have to hit the tyre on each side several times to bounce into onto the hub.
26-10-2005, 07:25 PM | #9 | ||
Kaddis Customs
actually come to think of it.. does it fit on but not all the way? because when i first got my wheels and i took one off i found it hard to get back on but i ended up getting it on. then after changing my diff it fitted on alot easier
26-10-2005, 07:27 PM | #10 | ||
PM me if you want
What you need is the bolts that go through the rim, they are skinny at the wheel end and have a normal head on them, that make sense
26-10-2005, 07:35 PM | #11 | |||
I can feel around the back and it feels like 15mm of gap. I only tried the front - didnt have time to try the back (it was getting dark) I did try hitting it on (only with my hands) - but I didnt want to force it on & then not be able to get it back off again! |
26-10-2005, 08:35 PM | #12 | ||
Sometimes wheels just get tight. I has a set of snowflakes on my car. when it came time to get new tires on another set of rims and **** the snowflakes off one side was totally stuck on the hub. The tire joint started hitting the inside of the tire with a rubber mallet. No luck. Then directly onto the rim, still wouldnt budge. He tried for ages. Then he tried a sledge against the tire and the stupid thing still didn't budge. In the end I told the guy to just belt the rim itself. while he belted it i kept turning the tire and after like 3 mins of constant belting it finally came off. The rim was pretty beat up.
Perhaps spray the hub with some light lube before putting the wheel on. it may help it slide on a bit easier. |
26-10-2005, 08:56 PM | #13 | ||
meow
lmfao @ ED = DA
26-10-2005, 09:32 PM | #14 | |||
Well its the same shape (and year model I beleive as the early E-Series.) Its an LTD model Falcon. The stud size should be the same? |
26-10-2005, 09:40 PM | #15 | ||
Last warning
yeah they're all 5x114.3
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
