29-01-2005, 08:41 PM | #31 | ||
Oh Yeah!
If you made the bit clear and the light use to take a clear bulb for the orange indicator... wouldnt that mean that a orange bulb wouldn't fit the socket which took the clear bulb?
Though nothing a bit of force couldnt fix. Maybe its different in the e-series but i know its like that in the au's. |
29-01-2005, 09:15 PM | #32 | ||
I build your wish list...
i have been wanting clear tail lights in my EL for a long time now and was ****ed at no one doing it so i started it my self
with a hole saw i cut a piece of red and orange (1 1/2 inch ) then smashed out all the lens , used a old bar heater to bend 1.5mm clear perspek and whirth glued the stop-tail red and orange blinker into it later i thought stupid me just use a vk commadore blinker.. well it leaks a bit to much 4 my likeing (and the cops) even with a good sealer around it. but i still want them so i went back and started again after i asked around at the summernatts and they told me they would not make any to suit so looks like if you want them you got to do them your self
If it weren’t for physics and the law enforcement, I’d be unstoppable.
29-01-2005, 10:13 PM | #33 | ||
windsor user
woah all that trouble.
you do realise that you could have fitted EF tail lights, which have a clear indicator! or do you mean the fooly ricer styles full clear light?? |
29-01-2005, 10:34 PM | #34 | ||
She needs premium dude...
mmmmm clear !!! Will post some pics soon of them on the car. Just need to buy the orange bulbs.
29-01-2005, 10:36 PM | #35 | ||
windsor user
steve you sly dawg.
i will give you some globes and holders if you help me to do my indicators. i tried to get them apart but couldnt |
29-01-2005, 10:44 PM | #36 | ||
Just a thought, how well is the light going to refract from the globe without that orange piece in there?
29-01-2005, 10:52 PM | #37 | |||
29-01-2005, 10:54 PM | #38 | ||
windsor user
perfectly well rob
the reflector is silver painted, and is staggered to reflect light out, all the orange does is change the colour from white light to orange light. if you put an orange globe in, it will reflect orange light just as well - thats all they did for the new monaro's exposed orange globe |
29-01-2005, 10:55 PM | #39 | |||
windsor user
i might have to have a go tomorrow looks like you still have a few bits of orange plastic in there - give em a really hard shake mate Last edited by LUXO_8; 29-01-2005 at 10:57 PM. |
29-01-2005, 10:59 PM | #40 | |||
Yeah the pic on the car is just a test fit. I washed all the crap out after the pic. Last edited by NC_Steve; 29-01-2005 at 11:00 PM. |
29-01-2005, 11:56 PM | #41 | ||
**** it, I'll give it a crack tomorrow!
har har har crack. |
30-01-2005, 11:29 AM | #42 | ||
Oh Yeah!
You could just get an AU then you have several rice lights to choose from.
Though for an E-eseries couldnt you find a altezza light from another car around the same size as an e-series one and get a plastic welder to fit it up?? Then just get some custom made clear perspex for the cover then you have some altezzas. |
30-01-2005, 01:35 PM | #43 | ||
Last warning
damn... those NC ones came up nice!
i look forward to seeing these on cars very soon
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
30-01-2005, 04:28 PM | #44 | |||
windsor user
dude, the whole point is we DONT WANT altezza lights, just clear lenses all round. personally i think altezza lights SUCK. |
30-01-2005, 07:19 PM | #45 | ||
Smashing the orange out on the sedans clearly isn't the way to go!
There's no way to get it all smashed up. |
30-01-2005, 07:28 PM | #46 | ||
windsor user
and you found that out on your good light didnt you?
off to JR's for a replacement |
30-01-2005, 08:27 PM | #47 | |||
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
30-01-2005, 09:13 PM | #48 | ||
Formerly mad_ed_wagon
me thinks the wagon will have el lookin lights tomorrow
30-01-2005, 09:14 PM | #49 | ||
Yep that's exactly what I did. I used a large flat blade screwdriver to break up the walls of the orange lens and break it in half. Then I used needle nosed pliers to grab the lens and pull it through the socket hole and once it got stuck in the hole I turned the pliers to shatter the lens bit by bit. I also found out today that the orange tinted globes don't fit in the sockets as those pins on the side of the globe are slightly offset differently. But it was nothing a few minutes with a die grinder didn't fix. _2:
30-01-2005, 09:14 PM | #50 | |||
windsor user
i was going to do it today but i left my pliars at work along with all the other headlight muck around tools that i have at work... might do it in my lunch time tomorrow. i already knew teh globes wouldnt fit in your holders was gonna mod em for ya Last edited by LUXO_8; 30-01-2005 at 09:15 PM. |
30-01-2005, 09:16 PM | #51 | ||
windsor user
the wagons have orange plastic lenses tommi, not the orange filter in the clear lights - you have to just replace the units with EL ones
30-01-2005, 09:32 PM | #52 | ||
lol I advise against the hammer and screwdriver method with the sedan.....I put a hole through the lense with the hammer. Glued it back on, keeps popping off when I close the boot lmao
30-01-2005, 09:46 PM | #53 | |||
30-01-2005, 09:57 PM | #54 | ||
windsor user
lol, how, by smashing the lens???
will fully laugh if you did.....! |
31-01-2005, 04:46 PM | #55 | ||
nah i wasnt that stoopid:P
i pulled out the globe shined a torch into the light and i could see the clear lense was on the inside:P i was about to get at it with a screwdriver but i wasnt sure cause it looked to me like the outer lens was painted hence the checking:P |
28-10-2005, 09:42 PM | #56 | ||
Mr. Multiple Projects
can someone who saved those pics of the lights repost them as they no longer work and im interested in the pics on page 2
