Old 28-09-2011, 02:50 PM   #1
turquoise
Default Reducing cabin noise
Hi Guys,
My ute is noisy inside the cab.
I went away on holiday for a couple of weeks and wasn't in/near a car at all. Got in my ute and headed up the highway and was struck by the amount of road/wind noise inside the cabin. After not going for a cruise for only 2 weeks I had to ask myself if the ute was always this noisy. Guess it was and I'd just gotten used to it.
As this drive makes up 90% of my driving (I do it twice a week, 2hrs in total each way; 1hr on 110km freeway and 1hr on 100km country 'b' roads). I naturally want it to be pretty comfortable.
I know that short of changing tyres I won't reduce noise from them (and being a tonner the susp. will be a bit harsh and not help the noise situation) but has anyone had a go at reducing cabin noise in general? Any pointers to reducing noise from the sills (the rubbers are in good condition, pretty fresh), etc?
I'm thinking of getting a heap of dynamat and installing it behind the door skins, under the carpet, headlining, rear cabin lining, anywhere else i can squeeze some. But it's not that cheap and i've never had any experience with it. Anyone used it? Does it work? Easy to install/work with? Should I spend up, go nuts with it and jam it into every crevice and behind every surface i can find? Any alternative products that people have had success with?
Answers to any and all questions are much appreciated and will be rewarded with beer*
*That's clearly a promise I can't keep but you do have my eternal gratitude!
AUI XL Ute in Fleet White
Country VIC
turquoise is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2011, 05:17 PM   #2
Day-mow
rexnet
Day-mow's Avatar
Default Re: Reducing cabin noise
Dynamat is a win! but its really expensive as well. that would be my sugestion though. or the paint on stuff. but i've not had much to do with it.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 28-09-2011, 08:58 PM   #3
fourl6
AU Falcon Man
fourl6's Avatar
When I changed the carpet in my forte to fairmont ghia stuff I noticed it was nearly twice as thick, I can't really remember if it made much of a difference, I only fitted it because it was black (old stuff was grey) but that could help.
One of the changes between AU1 and 2 was a laminated firewall to reduce road noise. But I don't think that would be possible or worth the effort
Cheers Cam
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2011, 10:56 PM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
I've had good results in the past with regular carpet underlay.... particularly if you can get the felted stuff!
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2011, 10:58 PM   #5
cartaa100
FG POWER
cartaa100's Avatar
dynmat is great but pricey.
maybe go to clark rubber and pick up some sheets of thick ruber.(not to thick it wont bend around the footwells bends).
id then lift up your carpet and shove it under there :P
2009 FG XR6 EGO
  http://fordforums.com.au/showthread.php?t=11332753
cartaa100 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 09:44 AM   #6
turquoise
Ok so I've been doing a bit of further reading, seems like there's 3 steps.
1. Dynamat to stop vibration of metal panels, needs to go directly against them to stop noise from their vibration
2. A noise barrier such as lead or vinyl over the dynamat (mass loaded vinyl seems to be the go, lighter and cheaper than lining your whole cabin with lead too!)
3. Some sort of foam over the top of this, I'm thinking clark rubber for the vinyl and foam, maybe wetsuit material if i can source enough cheap wetties!
So, the project begins...
Country VIC
Old 29-09-2011, 10:28 AM   #7
ronwest
All Bran = Regular Member
Years ago a mate of mine glued used carpet tiles to the floor and boot of his old rattler. At the time the carpet tiles were quite dense (about a kg each) with a rubber base. They may be different these days.
Worked a treat.
edit: also worked with a guy who used his old carpet tiles as soundproofing in a garage that he turned into a rumpus room. Just glued the tiles to the inside of the external wall before sheeting the plasterboard. Reckons it worked well.
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 10:31 AM   #8
JC807
sucksqueezebangblow
JC807's Avatar
i used the Jaycar version of Dynamat in the boot, combined with some foam underlay. stops heaps of noise.
previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUX, 06 BF XR6T, 08 V50 T5 AWD , MY13 ISUZU D-MAX 4X4
current:-> 16 SS Sportwagon, 19 Everest BiTurbo 4WD
JC807 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 11:22 AM   #9
Day-mow
rexnet
Day-mow's Avatar
also remember there are paint/spray on sound deadners. how ever i've not had anything to do with them. but its another option. probably cheaper then dynamat as well
Old 29-09-2011, 12:08 PM   #10
4ford
Smile Re: Reducing cabin noise
Are your door rubbers properly seated on the frames, otherwise they will create quite some wind noise, and it's an easy fix...
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 03:20 PM   #11
turquoise
Yeah I saw the paint/spray on products but as well as the CBF syndrome I also dont want the mess the could potentially make. Would also like to do the ute in sections at a time (eg. door, door, drivers footwell, passenger side, roof, rear of cabin) rather than pull out the entire interior to do a paint job.
No doubt carpet tiles work but looking for something i can easily secure on vertical surfaces as well as the underside of the bonnet (not sure about rubber and synthetic carpet just a few cms from the engine).
Looks like Jaycar have a few different products, have just ordered a sheet each of 2 different ones, will see how they go
Country VIC
Old 10-12-2011, 07:39 PM   #12
AU101
How did you go with it all turquoise?
AU101 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2011, 01:15 AM   #13
XR6SQ
I think some people might find this helpful http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
If you want some examples of sound insulation in cars head over to some car audio websites like http://www.diymobileaudio.com/forum/ and http://www.mobileelectronics.com.au/forums/.
AU111 XR6 Ute, VCT, Leather, Manual.
XR6SQ is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 09:01 AM   #14
b2tf
not here much anymore
b2tf's Avatar
I find the rear of the cabin wall to be the noisiest part so I would start with that area. Dynamat is just a brand name and there are plenty of other products on the market that would do a similar job at a much cheaper price.
2024 F150 XLT
Old 03-01-2012, 01:39 PM   #15
turquoise
Sorry for late reply AU101.
As it turns out, I haven't done a thing. Bought a '64 EH instead so all time and $$ going in to the new project
Country VIC
